I have tried to revert from Tomato to Genie and used the OFW file for the R7000 since I couldnt find any for the R8000. I can access the router through Genie, but it has changed into a R7000.
I have done multiple 30 30 30 resets, to no avail. Now when, in Genie, I try to restore to factory defaults the process does not finish. If I try to upgrade the firmware, I get a message saying that the firmware is invalid.
I have also tried to do the initial Tomato inatallation, but Genie does not accept it either since it thinks that my router is a R7000.
Should I install Tomato for the R7000:
Your suggestions will be much appreciated.
Luiz
Have the same issue back from tomato to ofw and use this file " R7000-back-to-ofw.trx" now i can't upload any image, router don't recognize Wan port ehh
Hi Frodo,
I can still run Genie as a R7000, but can;t activate WiFi, must plug the modem cable in a LAN port to have Internet access and it's impossible to update the firmware.
Maybe if I could delay the reboot process, the update would work because when I hold the reset button and cluck on update the process goes half way through. The update stops and the router finishes the reboot process. I have been reading about updating trhrough the serial port, so I might try it next since at this point I don't have much to lose.
Best of luck,
Luiz
