Re:
https://arstechnica.com/information-technology/2017/10/code-execution-fl...
The vulnerability has been patched:
http://svn.dd-wrt.com/ticket/5987
I use Dnsmasq extensively on my R8000. I've observered some anomolies in recent days, things like HTTPS not working on high-security sites (like banking), my guess is they're cert-pining and my SSL certificate chain-of-trust is invalid. This wasn't happening a few weeks ago, so something's amiss. Could be hacked or (??)
Should I go back to OEM firmware until Kong rolls patch into FW update?
I guess what I'm asking is how long can we expect it to take to get patched firmware. Will it be days, weeks, or months?
Not bagging on Kong, dd-wrt, etc! You guys are doing excellent work! Just need advice on what to do here.
Thanks & props to the devs...
(+1)
I have an R7800 on which I have been running Kong's builds. I noticed the same article today and am anxious to install an updated build of DD-WRT. Thank you Kong and other devs for your past and future work on DD-WRT!
