Firmware: DD-WRT v3.0-r30870M kongac (11/10/16)
I setup port 5003 (Filemaker Server) to forward and for some reason this port doesn't work. Everyother port works.
I have tried port forwarding range, I have tried standard port forwarding nothing worked, I have rebooted the router, I have turned out the services and turned back on with no solution.
I hope someone provide me a solution.
Thank you
This worked before I upgraded to DDWRT
You really need to read. Port forwarding is for static IP's, so if that's not set your going to be frustrated. it's not the routers fault, and DD-WRT is not meant for those looking for the click a button approach, it is for those wishing to go well beyond. That said, some reading will list numerous solutions to the issue as your not the first.
Do you use an external modem ? i.e use a VDSL modem.
You must set it up properly, it is not just one tab.
And another thing, if you have UPNP on it will over write your forwards. So don't do that.
