DD-WRT and LEDE speed cap
7 posts / 0 new
Nit3H8wk
With DD-WRT i get close to 850Mb down with LEDE I get close to 800Mb down. Is there anyway to get close to stock speed which are http://www.speedtest.net/my-result/6836226806
On stock with wifi i get over 700Mb down with ddwrt or lede 400-450.
e38BimmerFN
What are your speeds LAN
What are your speeds LAN wired when speed testing. It's not recommended to test wireless as wireless has many variables that can cause inaccurate results.
Test with any QoS disabled first.
Nit3H8wk
Wired i get up to 850Mb down
Wired i get up to 850Mb down on DD-WRT and 800Mb with openwrt. Assuming DD-WRT is slightly faster due to shortcut forwarding engine. With stock firmware http://www.speedtest.net/my-result/6839454376
Nit3H8wk
Also i have QoS turned off as
Also i have QoS turned off as i have 1 gig internet and only 3 devices connected to it one of which is wired to a killer nic.
e38BimmerFN
Looks like OEM FW is going to
Looks like OEM FW is going to be the best bet. I presume the OEM fw has HW NAT accelleration enabled thus your getting 900~Mb. This will be the limit of this and most other routers, regardless of FW and 1Gb ISP speeds.
3rd party FW may not be fully tuned for 900~Mb and thus you may see some differences. I would use what works best.
Nit3H8wk
https://forum.lede-project
https://forum.lede-project.org/t/qualcomm-fast-path-for-lede/4582/486
https://github.com/paul-chambers/netgear-r7800/blob/master/package/short...
I guess i would have to compile openwrt from linux to do qualcomm fast path which is hardware nat?
e38BimmerFN
Might see if LEDE already has
Might see if LEDE already has a build that would work or a package that could be installed on LEDE. I know that OpenWRT and LEDE are FWs that have customizable environements where you can install them, then there is a menu listing of all the packages available that you can install after the fact. Big list too. You might ask over on the LEDE or OpenWRT forums about this...
