Hi board,
Anyone tried the Merlin Asus WRT firmware already on the R6400v1?
I am using dd-wrt for a year now but now saw that this firmware is available too.
I will try it tomorrow and report back. Looks promissing.
https://upsangel.com/home-security/shadowsocks-vpn-server-on-merlin-r6400-guide/
https://firmware.koolshare.cn/merlin_8wan_firmware/R6400/
Cheers
Wow. After one day messing around with this Merlin firmware I must say: never back to dd-wrt again. Sorry. Everyting is in there.
I highly recommend the V7.6 firmware.
Install:
flash initial from dd-wrt or stock: https://firmware.koolshare.cn/merlin_8wan_firmware/R6400/Netgear%20R-series%20initial%20files/R6400_380.63_2_X7.2.1.chk
telnet (putty) to 192.168.1.1
login admin/admin
nvram clear + reboot
again login
Back to OFW and then dd-wrt again. My son experienced xbox connection lost with Rainbow Six Siege servers. Pitty.
More info about this fw in this chinese forum: http://koolshare.cn/thread-72576-1-1.html
Did another try with this firmware. Now on version 7.5 and that is stable. My advise is to use version 7.5.
https://firmware.koolshare.cn/merlin_8wan_firmware/R6400/X7.5/R6400_380.66_4-X7.5-610.trx
Cheers
very intrigued by this, however its all a bit confusing with the translations google is providing. could you post a quick step by step here so i can do this successfully
Well it is very easy to install if you have dd-wrt already running. First make a proper backup of your current dd-wrt configuration!
Install Asus Merlin
flash initial from dd-wrt or stock: https://firmware.koolshare.cn/merlin_8wan_firmware/R6400/Netgear%20R-series%20initial%20files/R6400_380.63_2_X7.2.1.chk (note this is CHK file, flash with "clear settings" checked!)
wait for 3-5 minutes and connect to open "NETGEAR" wifi
telnet (putty.exe) to 192.168.1.1
login admin/admin
again login
didnt need to do any telnetting, it just worked once i entered my isp's login details didnt need to do any nvram setting either! win!
Well you don't understand the meaning of the NOASUS setting. Try and see what happens after reboot :)
why dont you just tell me what it does, so i can decide its worth it or not?
I have registered a free ddns with changeip.com and added this script to update my wan ip to my registered domain.
/jffs/scripts/ddns-start
I'm trying this now, but it looks like the back_to_ofw.trx file isn't downloading for me? Would the one provided by shibby for Tomato work?
When you are on this Merlin based R6400 firmware the back_to_ofw.trx should work. I have tried it already.
You get stock Netgear fw again.
More nice features!
To enabled LEDS read this in the wiki. Ik works. https://github.com/RMerl/asuswrt-merlin/wiki/Scheduled-LED-control
In short:
My /jffs/scripts/ddns-start script:
Somebody here tested this chinese Leap_ahead build on R6400 version 2? I´m afraid to brick my router.
There is a little risk. Although soc is newer revision at higher freq. In worst case you need to use tftp and ethernet cable to roll back to stock firmware.
You cannot completely brick it with flashing wrong firmware. But that depends on your skills to revive it with tftp.
More about tftp recovery: https://www.dd-wrt.com/wiki/index.php/Tftp_flash
Hi.
Is anybody using version 7.7 ?
Is ther a big difrence between 7.5 or 7.6 ? I dont know chinese so cant tell what changed in this builds.
New firmware V 7.8 download link here: http://firmware.koolshare.cn/merlin_8wan_firmware/R6400/X7.8/R6400_380.69_2-X7.8-ks.trx
Changelog: https://github.com/RMerl/asuswrt-merlin/blob/master/Changelog.txt#L4-L107
Have not tried it myself. I am still stable on 7.5 !!!
New Firmware V 7.9 is out. Download link:
https://firmware.koolshare.cn/Koolshare_Merlin_Legacy_380/Netgear/R6400/...
Last in the 380. Now focus on 384. May take a while.
https://firmware.koolshare.cn/Koolshare_Merlin_New_Gen_384/
Cheers
I would like to try the 7.5 since it is stable, but the chk file link is just a 404 for me. Any new links/mirrors?
Seems links were repositioned, new links are in
Mentioned ithis in other topic.
Thank you "tweakradje" for your posts!
I'm using the version 7.9 already for a week and is working everything fine
On version 7.9 don't works and don't need telnet commands to enable the Asus features (nvram set NOASUS=0).
To enable Asus features is now more easy, from router web gui: Tools -> Other settings -> Asus Features (at the bottom of the page) -> Enable BWDPI: Yes / Enable AiCloud: Yes -> Apply -> Reboot
How is the 2.4ghz performance?
I read somewhere that on the R6400v1 Wlan drivers are somewhat closed source and only kong mod has managed to fully utilize 2.4ghz, even Tomato has bad performance.
In my case with advanced tomato i reach a maximum of 100mbit/s with iperf.
I wonder if anyone can help me. I had DD-wrt (Kong) and wanted to try Merlin. I have R6400v1.
I used https://firmware.koolshare.cn/merlin_8wan_firmware/R6400/Netgear%20R-series%20initial%20files/R6400_380.63_2_X7.2.1.chk to flash first. This seemed to go OK but I am unable to go any further
My old SSID is still working even though I asked to reset defaults in flash page on dd-wrt. The router has rebooted and when I connect to wireless SSID I can get out to the internet.
I have tried connecting via browser and via putty on address. I know this address is OK as arp shows the MAC adress on the IP to 10DA43 which is a netgear MAC. I can ping and get a response from the router. I can telnet OK to the router and can use the old username/password combo to get in.
I have an nvram backup of DD-wrt taken prior to flashing first chk file. As I have a working INternet connection, I want to check what others think the possibilities are before continuing.
Thanks in advance
Had to do a hard reset and I now have 7.5 working. I tried 7.9 but it failed. Tried to do firmware upload from 7.5 as well and it says unsuccessful.
I have checked the MD5/SHA1 has and they check out so the file has downloaded ok.
Will keep trying to see what happens.
"R6400_380.70_0-X7.9.chk" (file extension .chk) is to upload the Merlin firmware direcly fom the original Netgear's stock firmware. If you have already the Merlin firmware installed on your R6400 you should use the file with .trx extension:
Updated link "R6400_380.70_0-X7.9-koolshare.trx"
V 7.9.1 download links:
TRX https://firmware.koolshare.cn/Koolshare_Merlin_Legacy_380/Netgear/R6400/...
CHK https://firmware.koolshare.cn/Koolshare_Merlin_Legacy_380/Netgear/R6400/...
Thx for the update notice. Checngelog here: http://koolshare.cn/thread-139324-1-1.html
Only change from 7.9 is the Koolshare store part. Backup your /jffs, update to 7.9.1, format /jffs and restore /jffs if you want to update. I don't use that part so no update for me. Happy with 7.9 :)
