Hi
I have a Nighthawk R8500 with
DD-WRT Kong Mod for NETGEAR R8500 (2017-11-04 CHK) installed.
I would like to remove that firmware and restore to a factory(Original) firmware.
I followed this link to restore the firmware without luck.
I would appreciate some help.
i also installed ddwrt on my R8500, it doesnt seem to support my VPN or it wont connect to it. Why does it allow installation of the Factory firmware? when flashing it does state successful but it opens back to ddwrt. can someone please help me get my router back to factory?
This worked for me.
https://www.myopenrouter.com/forum/unable-flash-stock-firmware-kong-dd-wrt
actuall i got it to work by changing the setting in my ethernet adapter. i went in and type the same ip address as the router creating and conflict after saving it i went back in and replce ip with assign automaticly and then Genie pop up came and i was able to get the back back to factory. thanks for everyone help.
