Hi All,
actually I deployed a 3500lv2 as Wifi bridge to work on network devices. I would like to mirror the entire traffic (wired/WIFI ) on a dedicated ethernet port to sniff it on a monitoring and capture host.
Ufortunatly the only example I found is iptables mangle witch not does doing the job ( no traffic is redirected to my host ):
iptables -A PREROUTING -t mangle -j ROUTE --gateway 192.168.1.11
iptables -A POSTROUTING -t mangle -j ROUTE --gateway 192.168.1.11
An this is not what I execpt , what I exepect is is more a physical port mirroring whereas WLAN traffice is listened .
Today routeur is running TomatoUSB 1.28 and is configured as Wireless ethernet bridge.
Do you know how to mirror all traffic on a dedicated phycal port ?
Thank you .
Hi all , unfortunatly I did find the way to mirror using tomato firmware. I had to by a other one router for that.
Hi all , unfortunatly I did not find the way to mirror using tomato firmware. I had to by a other one router for that.
