R7000 To DDwrt Kong Mod
4 posts / 0 new
Pit_g
In downloads i only see a  .CHK  File to flash. my R7000  .....no   .BIN  file?????
is only needed .CHK file for flash R7000 to Kong Mod????
sshahed10
Seems that's the only file
Seems that's the only file you need.
Pit_g
Ok   Thanks Bro
Ok
BR972
 Routing prioritization on
 Routing prioritization on R7000P ?
Hello, I have a R7000P router with Netgear software connected on a adsl modem and I wish to prioritize Ethernet traffic on the ports compared to wifi traffic because my bandwidth is very low and the traffic that goes on my Samsung TV (connected to the R7000P) must go before others. Unfortunately, I have not yet found a way to do this because my network knowledge is still very limited. Would there be a good soul to be very pedagogue with me?  Thanks in advance
