Does Voxel firmware support seperate VLANS on 4 ports?
2 posts / 0 new
gokuz
gokuz's picture
As per topic, does Voxel firmware support seperate VLANS on 4 ports?
Not to be confused with ISP VLAN tagging.
I want to have multiple VLANS to isolate LANS, i.e. [192.168.1.1 on port 1], [192.168.2.1 on port 2]
My previous ASUS N66U merlin could achieve this using  "/jffs/configs/dnsmasq.conf.add"
Does voxel support this, maybe in GUI as well?
Wouldn't want to go ddwrt/lede as it is slow, having 1Gb connection here. Did some search and came out empty. Maybe voxel himself might be able to help.
Groove60
Groove60's picture
Funny seeing this here, as I
Funny seeing this here, as I am looking forward to implementing the same thing you are. I have been researching this for weeks and can't seem to come up with a solution with my current hardware. Also can't use DDWRT as I have giga as well.
I have the R7800 as my gateway and a port off of that is going to a secondary router (DDWRT) I want to use for IOT devices. I want to isolate both networks while retaining the ability for the secondary router to access the internet. Unfortunately, even A (LAN)->(WAN) B allows B devices to ping A devices.
I think I can use a VLAN to get the desired outcome, but like you said - the router VLAN functionality seems to be an ISP IPTV style function. Any help with this is appreciated!
