Default WPA2 Password
5 posts / 0 new
cglass17
cglass17's picture
First off, all of my LAN ports are bad. So I can not connect via a hardwire. I was trying to convert to a wireless range extender.  I managed to download and install the latest dd-wrt firmware. However, when I try to connect via WIFI to dd-wrt it is requesting a WPA2 password. I also tried 30/30/30 with the same results.
Any suggestions?
Funnief13
Funnief13's picture
Hi did you ever figure the
Hi did you ever figure the password? I got the same problem here.
amlucent
amlucent's picture
Ditto, same problem.
Ditto, same problem. Undocumented any fucking where. Maybe my swear will attract attention to this issue
vdams
vdams's picture
same pb
same pb
vdams
vdams's picture
found: same like written
found: same like written under router: mo*********h809
