Hi all,
I am curious how most users restore custom router settings after they update their DD-WRT firmware?
The online documentation/guide for DD-WRT recommends that router should be reset to default settings after a firmware upgrade and that we should not restore from the settings file exported previulsy by the old firmware.
What this means to me is that users who have configured a lot of custom parameters in DD-WRT would need to re-enter all those configurations again after each update.
It would probabaly take me up to 20 to 30 minutes to re-type all my custom configurations. Call me lazy but I would prefer not have to spend time re-enter configurations.
For many years, each time after I installed DD-WRT on a new router and enter my custom configurations, I almost never bother to update the firmware again unless the firmware has problems.
Any information on how to best restoring configurations after DD-WRT update would be appreciated.
Thank you.
I think under the administration tab you have the option to backup your config. Use that, save the file then just restore after next update. Works perfect.
Hi MrMad,
That is what I hope can be done (without problems).
However, listed under the "Upgrading to a Newer Version of DD-WRT" section on DD-WRT Wiki page http://www.dd-wrt.com/wiki/index.php/Installation , it says:
However, it is highly recommended that you restore the router to defaults using the reset button before and after flash. Never restore old backups from previous versions! Skipping these steps could lead to a bricked device!
Should I ignore that advice?
Perhaps the recommendation on the Wiki page was for very old version of DD-WRT?
+1
yep, I am having exactly the same question / concern as the OP.
