Unable to go back to Netgear firmware from DD-WRT (r7800)
4 posts / 0 new
shinb0
shinb0's picture
Hello everyone,
I got my self a R7800 and flashed it to DD-WRT, but I've tried to go back to netgear because I'm having some internet issues and it will flash and say its successful but end up still on DD-WRT.
I used this file from the firmware website  "ddwrt-netgear-R7800"  Is there something that I'm doing wrong?
XunilinuX
XunilinuX's picture
Did you revert to stock using
Did you revert to stock using:
http://desipro.de/ddwrt/K3-AC-IPQ806X/NetgearFW/
Don't forget to read and execute the instructions of the FAQ file in this directory.
XunilinuX
XunilinuX's picture
After having flashed Kong's
After having flashed Kong's DD-WRT, I forcefully bricket my R7800 (pulling the plug while I was flasing the "ddwrt-to-netgear-fw-R7800.bin" from the above link).
Yes, other than one or two blinking lights, it was a great paperwieght for a few minutes.
https://kb.netgear.com/22688/How-to-upload-firmware-to-a-NETGEAR-router-...
Using the above method to flash the same image (ddwrt-to-netgear-fw-R7800.bin) my router was resuscitated.
gallo
gallo's picture
if the gui version of tftp2
if the gui version of tftp2 fails which happens sometimes, initiate the transfer from a cmd window "tftp -i 192.168.1.1 put r7800xxxx.img" replace r7800xxxx.img with the actual firmware name, minus the quotes
