This is my first time trying to use DD-WRT, and I'm seeing some strange behavior. My router is brand new, and still running the stock firmware. I've been trying to upload R7500v2-factory-to-ddwrt.img via Advanced>Admin>Firmware Update, as the first step before then flashing with ddwrt-netgear-R7500v2.bin. But every time I do, the upload seems to hang. I can tell when the upload is finished by monitoring the bandwidth on my laptop, and I'll wait ~10min afterward before refreshing the page to the admin console. The stock firmware seems to be running as though nothing happened. I've done the 30/30/30, and I've rebooted and soft-reset multiple times.
Has anyone seen this behavior before?
I have the same problem, LEDE is the only thing works
I’m also having this issue, I downloaded the files from Kong’s website I loaded factory to dart and when I try to upload any bin it just stops at 1%.
I was facing the same issue with my Netgear router. The internet service also very slow. how can I make it faster? I need a proper help for this?
