The original/stock Netgear firmware for my X6 has no configuration control for firewall settings and I need to be able to allow ports 5060 & 5070 for VoIP can anyone advise if any of the open source/custom firmware available allows for configuration of firewall rules?
Also, I've been trying to connect my Windows computer using OpenVPN, however, I can't as the connect has issues with the certificate that my X6 has generated,is there a fix for this with any custom firmware?
Stock firmware can be configured to allow port fordwarding or triggered which will allow the ports you need for VoIP, no custom firmware is needed for that.
What kind of certificate error are you getting? Post a SC would be helpful.
