The R7800 has no HW clock, so it relies on internet ntp-time from Netgears servers.
From Voxels readme.docx, chapter 8:
NOTE: you can add your own delay for starting OpenVPN client after reboot by the command from telnet:
(to set 120 sec. delay)
Thank you, do you think this delay should be enough for getting the system time?
Yes 200 seconds should be enough.
But if you don't want to have a hard-coded delay you can add edit the file /etc/init.d/openvpn-client like this:
After the line "START=99"
you add this line:
while [ ! -e /tmp/ntp_updated ]; do sleep 1; done
This will pause the start of the openvpn client until time is synchronized.
