Clueless WAN disconnects on Voxel V1.0.2.50SF (R7800)
3 posts / 0 new
Cysol
Cysol's picture
I am stuck here with seemingly random WAN disconnencts. The only thing I could vaguely trace it to is, that the disconnects mostly occur when I'm using my computer or my voip box is being called. Both of them not an ideal situation as you could imagine.. Console-log included below.
Please help I am kind of desperate
Booting Linux on physical CPU 0
Linux version 3.4.103 (voxel@dell) (gcc version 4.8.5 (GCC) ) #1 SMP Mon Apr 2 16:46:32 UTC 2018
CPU: ARMv7 Processor [512f04d0] revision 0 (ARMv7), cr=10c5387d
CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
Machine: Qualcomm Atheros AP161 reference board
QCA command line: console=ttyHSL1,115200n8
DNI command line: console=ttyHSL1,115200n8 ubi.mtd=netgear root=/dev/mtdblock6
msm_reserve_memory: 0x44600000, 0x200000
memory pool 3 (start 5fc00000 size 400000) initialized
Memory policy: ECC disabled, Data cache writealloc
smem_find(137, 80): wrong size 72
socinfo_init: v6, id=280, ver=3.0, raw_id=17, raw_ver=17, hw_plat=0,  hw_plat_ver=65536
 accessory_chip=0 hw_plat_subtype=0
PERCPU: Embedded 8 pages/cpu @c0d53000 s10624 r8192 d13952 u32768
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 123178
Kernel command line: console=ttyHSL1,115200n8 ubi.mtd=netgear root=/dev/mtdblock6
PID hash table entries: 2048 (order: 1, 8192 bytes)
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 49MB 436MB = 485MB total
Memory: 482500k/488644k available, 14140k reserved, 0K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    vmalloc : 0xdf000000 - 0xff000000   ( 512 MB)
    lowmem  : 0xc0000000 - 0xdeb00000   ( 491 MB)
    pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    modules : 0xbf000000 - 0xbfe00000   (  14 MB)
      .text : 0xc0008000 - 0xc0631000   (6308 kB)
      .init : 0xc0700000 - 0xc0802980   (1035 kB)
      .data : 0xc0804000 - 0xc08a79a0   ( 655 kB)
       .bss : 0xc08a79c4 - 0xc094f418   ( 671 kB)
SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
Hierarchical RCU implementation.
NR_IRQS:1689
sched_clock: 32 bits at 32kHz, resolution 31240ns, wraps every 134175798ms
Console: colour dummy device 80x30
Calibrating delay using timer specific routine.. 12.55 BogoMIPS (lpj=62785)
pid_max: default: 32768 minimum: 301
CPU: Testing write buffer coherency: ok
CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Setting up static identity map for 0x4195f308 - 0x4195f390
CPU1: Booted secondary processor
CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
Brought up 2 CPUs
SMP: Total of 2 processors activated (25.11 BogoMIPS).
dummy:
AXI: msm_bus_fabric_init_driver(): msm_bus_fabric_init_driver
meminfo_init: smem ram ptable found: ver: 0 len: 5
Found 1 memory banks grouped into 8 memory regions
gpiochip_add: registered GPIOs 0 to 151 on device: msmgpio
msm_rpm_init: RPM firmware 3.0.16777364
clk_tbl_nss_fast - loaded
msm_dmov_memcpy_init: Success
sps:BAM 0x12244000 enabled: ver:0x5, number of pipes:20
sps:BAM 0x12244000 is registered.
sps:sps is ready.
msm_pcie_setup: link initialized
PCI host bridge to bus 0000:00
pci_bus 0000:00: root bus resource [mem 0x08000000-0x0fefffff]
PCI: bus0: Fast back to back transfers disabled
pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
PCI: bus1: Fast back to back transfers disabled
PCI host bridge to bus 0000:02
pci_bus 0000:02: root bus resource [mem 0x2e000000-0x31efffff]
PCI: bus2: Fast back to back transfers disabled
pci 0000:02:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
PCI: bus3: Fast back to back transfers disabled
msm_pcie_setup: link initialization failed
pci 0000:02:00.0: BAR 8: assigned [mem 0x2e000000-0x2e1fffff]
pci 0000:03:00.0: BAR 0: assigned [mem 0x2e000000-0x2e1fffff 64bit]
pci 0000:02:00.0: PCI bridge to [bus 03-03]
pci 0000:02:00.0:   bridge window [mem 0x2e000000-0x2e1fffff]
PCI: enabling device 0000:02:00.0 (0140 -> 0143)
pci 0000:00:00.0: BAR 8: assigned [mem 0x08000000-0x081fffff]
bio: create slab <bio-0> at 0
ADDR               AID CHAN TXRATE RXRATE RSSI IDLE  TXSEQ  RXSEQ  CAPS        ACAPS     ERP    STATE MAXRATE(DOT11) HTCAPS ASSOCTIME    IEs   MODE PSMODE
[MAC]    1   44 634M    513M   30    0      0   65535    EP         0          b              0           AWPS 00:00:05 RSN WME IEEE80211_MODE_11AC_VHT80  0
[MAC]    1    4  76M     25M   36 4320      0   65535  EPSs         0          f              0              P 00:00:08 RSN WME IEEE80211_MODE_11NG_HT20  0
[MAC]    2    4  70M     12M   44 4320      0   65535  EPSs         0          f              0           WQGS 00:00:07 RSN WME IEEE80211_MODE_11NG_HT20  0
[MAC]    3    4   0M      0M   32 4320      0   65535  EPSs         0          f              0              Q 00:00:07 RSN WME IEEE80211_MODE_11NG_HT20  0
[MAC]    4    4  38M      0M   42 4320      0   65535  EPSs         0          f              0              P 00:00:06 RSN WME IEEE80211_MODE_11NG_HT20  1
### Tx ###
comp_queued       :559
comp_delivered    :840
msdu_enqued       :668
wmm_drop          :0
local_enqued      :275
local_freed       :275
hw_queued         :670
hw_reaped         :670
underrun          :0
tx_abort          :0
mpdus_requed      :27
excess retries    :15
last rc           :215
sched self trig   :0
### Rx ###
status_rcvd       :385
r0_frags          :0
r1_frags          :0
r2_frags          :0
htt_msdus         :320
htt_mpdus         :289
loc_msdus         :64
loc_mpdus         :64
oversize_amsdu    :0
phy_errs          :0
phy_errs dropped  :0
mpdu_errs         :4
txrx stats:
  tx: 1049342114791825 msdus (0 B)
  rx: 335170657845574 msdus, 0 bytes
ast_be_xmit         :265
ast_be_nobuf        :0
ast_tx_buf_count    :2500
ast_tx_packets      :676
ast_rx_packets      :392
ast_tx_mgmt         :275
ast_tx_nobuf        :0
ast_tx_xretries     :15
ast_rx_num_data     :326
ast_rx_num_mgmt     :27
ast_rx_num_ctl      :0
ast_tx_rssi         :4294967168
ast_rx_rssi_comb    :32
ast_rx_rssi_chain0  :281100
ast_rx_rssi_chain1  :28190
ast_rx_rssi_chain2  :27180
ast_rx_rssi_chain3  :16240
ast_rx_bytes        :113901
ast_tx_bytes        :248124
tx_compaggr         :197
rx_aggr             :5
tx_retries          :27
tx_xretries         :0
tx_bawadv           :516
tx_compunaggr       :61
ast_rxorn           :0
ast_txurn           :0
ast_txto            :0
ast_mib             :0
ast_rx_badcrypt     :0
ast_rx_badmic       :0
target assert count :0
noise floor         :-107
Last MSDU unset cnt :0
 Rx MCS STATS:
 mcs 0- mcs 4 STATS:    21,     2,     0,     0,     0,
 mcs 5- mcs 9 STATS:     4,   263,     9,     0,     0,
 Tx MCS STATS:
 mcs 0- mcs 4 STATS:     0,     0,     0,     0,     0,
 mcs 5- mcs 9 STATS:     4,   151,    36,     1,     0,
Saving Data...
Done!
vap-0: [ROUTER_MAC]ieee80211_beacon_update: TIM updated, pending 1, off 0, len 1
vap-0: [ROUTER_MAC]ieee80211_beacon_update: TIM updated, pending 0, off 0, len 1
end action
[wifi1] FWLOG: [74143] WAL_DBGID_TX_BA_SETUP ( 0x44902c, 0xf2750000, 0x0, 0x40, 0x1 )
vap-0: [00:fc:8b:69:92:2a]UAPSD bit settings from STA: 00vap-0: ieee80211_parse_htcap:SM powersave disabled
vap-0: ieee80211_parse_htcap:calculated updaterates 0x1
vap-0: ieee80211_parse_htcap: ni_htcap 0x1ad
vap-0: ieee80211_update_noderates: updating rates: smen 1 dyn 0 ratechg 0
[wifi1] FWLOG: [75427] RATE: ChainMask 3, peer_mac 92:2a, phymode 5, ni_flags 0x00201006, vht_mcs_set 0x0000, ht_mcs_set 0xffff, legacy_rate_set 0x126d9
[wifi1] FWLOG: [75481] WAL_DBGID_SECURITY_UCAST_KEY_SET ( 0x922a, 0x0 )
[wifi1] FWLOG: [75481] WAL_DBGID_SECURITY_ENCR_EN (  )
[wifi1] FWLOG: [75481] WAL_DBGID_SECURITY_ALLOW_DATA ( 0x448f4c )
=================DNS_RESOLV
[wifi1] FWLOG: [77413] WAL_DBGID_TX_BA_SETUP ( 0x448f4c, 0x922a0006, 0x2, 0x20, 0x1 )
[wifi1] FWLOG: [77414] RATE: ChainMask 3, peer_mac 92:2a, phymode 5, ni_flags 0x00201006, vht_mcs_set 0x0000, ht_mcs_set 0xffff, legacy_rate_set 0xefdc6988
[wifi1] FWLOG: [77988] WAL_DBGID_TX_BA_SETUP ( 0x448f4c, 0x922a0000, 0x1, 0x20, 0x1 )
vap-0: [dc:ef:09:f2:67:33]ieee80211_beacon_update: TIM updated, pending 1, off 0, len 1
vap-0: [dc:ef:09:f2:67:33]ieee80211_beacon_update: TIM updated, pending 0, off 0, len 1
[wifi1] FWLOG: [81131] WAL_DBGID_TX_BA_SETUP ( 0x44910c, 0xca1b0006, 0x3, 0X10, 0x1 )
[wifi1] FWLOG: [81132] RATE: ChainMask 1, peer_mac ca:1b, phymode 5, ni_flags 0x00041006, vht_mcs_set 0x0000, ht_mcs_set 0x00ff, legacy_rate_set 0xea800000
[wifi1] FWLOG: [85631] WAL_DBGID_TX_BA_SETUP ( 0x44910c, 0xca1b0000, 0x0, 0X10, 0x1 )
sysinit: POT is Finished!!!
vap-0: [84:b5:41:95:ba:bc]UAPSD bit settings from STA: 00vap-0: ieee80211_parse_htcap:switching to static SM power save
vap-0: ieee80211_parse_htcap:calculated updaterates 0x2
vap-0: ieee80211_parse_htcap: ni_htcap 0x20
vap-0: ieee80211_update_noderates: updating rates: smen 0 dyn 0 ratechg 0
[wifi1] FWLOG: [123027] RATE: ChainMask 1, peer_mac ba:bc, phymode 5, ni_flags 0x00041006, vht_mcs_set 0x0000, ht_mcs_set 0x00ff, legacy_rate_set 0x1e0ff
[wifi1] FWLOG: [123135] WAL_DBGID_SECURITY_UCAST_KEY_SET ( 0xbabc, 0x0 )
[wifi1] FWLOG: [123135] WAL_DBGID_SECURITY_ENCR_EN (  )
[wifi1] FWLOG: [123135] WAL_DBGID_SECURITY_ALLOW_DATA ( 0x448e6c )
[wifi1] FWLOG: [125168] WAL_DBGID_TX_BA_SETUP ( 0x448e6c, 0xbabc0006, 0x2, 0x40, 0x1 )
[wifi1] FWLOG: [125169] RATE: ChainMask 1, peer_mac ba:bc, phymode 5, ni_flags 0x00041006, vht_mcs_set 0x0000, ht_mcs_set 0x00ff, legacy_rate_set 0x0000
[wifi1] FWLOG: [126064] WAL_DBGID_TX_BA_SETUP ( 0x448e6c, 0xbabc0000, 0x0, 0x40, 0x1 )
sysinit: Can't gethostbyname for dynupdate.no-ip.com
sysinit: Can't get our visible IP address from ip1.dynupdate.no-ip.com
Greetings
Mike_r1
Mike_r1's picture
I don't know whether this
I don't know whether this will be helpful at all, but there are many threads on R7800 WAN disconnects all over the web, most with stock Netgear firmware, and some going back a year or so.  I personally had the same issue with WAN disconnects after upgrading to the latest Kong mod of DD-WRT from Feb. 15th, 2018.  My WAN ports would disconnect sometimes only after a few hours, while WiFi would continue working without any issue. This happened on all four WAN ports overnight with 100% repeatability. A reboot usually fixed it, but I got sick of restarting the router several times a day, and I've reverted back to Netgear stock firmware v1.0.2.46 for now.  So far no disconnects but I've only been up on it for two days.  Not a real solution but something to consider.
I'm planning to try Voxel when I don't have to work from home and have a bit of a lull.
e38BimmerFN
e38BimmerFN's picture
What is the Mfr and model# of
What is the Mfr and model# of your ISP modem/ONT?
Another item to look for is cabling. Swap out cabling and test.
I've never had any issues with my R7800 however I have been using stand alone ISP modems, no built in router modem combo units.
