static ip
4 posts / 0 new
kcmccombs
static ip
hello i just got my R9000 up and running can someone tell me how to setup static ips for my devices.thanks
cybersade
you can find it under
you can find it under advanced setup
kcmccombs
is this where i would make my
is this where i would make my devices set to a static ip or for making the route have static ip
cybersade
this would be for devices, as
this would be for devices, as for the router it would have the internet wan adress given out by ISPs dont recommned changeing that and then of course the internal LAN adress range that you can change under advanced, setup, LAN setup
