Hi !
I'm running "DD-WRT v24-sp2 (10/07/14) kongac - build 25090M" firmware and I want to upgrade to the newer stable version.
Reading FAQs and tutorial I understand that I can do it by web inteface using bin file and reseting to factory defaults after.
Problem is there's no bin file for R7000 on http://www.desipro.de/ddwrt/K3-AC-Arm/ , I only see a chk for initial flashing coming from NetGear's firmware. Should I use chk file like bin file in web interface ?
Found it thanks to https://www.myopenrouter.com/forum/r7000-bin-missing-2017-november-builds
Same probleme for
DD-WRT Kong Mod for NETGEAR R7000 (2018-02)
I find
but I don't find .bin version please help me
I have also ddwrt version ... just want upgrade .... Thank's a lot ...
ok i just read that :
If undestand I must download
isnt 'it ?
isnt 'it ?
I am looking for a configuration step by step for maximum security ... to optimize ddwrt ... Wifi, firewall, vpn ... I saw this tutorial with 16 steps
https://www.tubefr.com/installer-et-configurer-un-dd-wrt-kong-routeur_10...
Is it still relevant ?
