setting up client for 802.11-X WPA2 Enterprise MSchapv2 network
2 posts / 0 new
stirliz
Hey everyone
I am trying to use the router to share the Wifi Hot-Spot from my provider when I am at a summer house. It uses 802.11-X WPA2 Enterprise with MSchapv2. Voxxels version does not support Enterprise at all (which is unfortunate, as I find DD-WRTs interface very unfriendly) and with Kongs DD-WRT I seem not to have success. I seem to connect to the network, but there is not internet connection.
I read on another forum for another DD-WRT device, that you need to add WPA-Supplicant for proper funktionality, though it seems that in Wireless security options there already is WPA2Enterprise with PEAP.
After hours of trying and failure I am confused - can someone help me out here?
Many thanks in advance,
vonStirliz.
e38BimmerFN
Not sure if this will help
Not sure if this will help any, seen Voxel talk about the Entware and packages being added there, you might check the Entware feature to see if the additional package you need can be added there. If it's available. You might send Voxel a PM to get his attention on this...
