Trying to unbrick R8000
6 posts / 0 new
michelle911
I have the putty window open and connected but it doesn't seem to be working. Can anyone steer me in the right direction?
Digital core power voltage set to 1.0V
Decompressing...done
SHMOO VER 1.13
PKID07DC06011801080000000000001A103F01000000
S300001B3
00001190
RDLYW0 00000004
RDENW0 00000031
RDQSW0
    0000000000111111111122222222223333333333444444444455555555556666
    0123456789012345678901234567890123456789012345678901234567890123
 00 ------+++++++++++++++++++++++X++++++++++++++++++++++------------
 01 ----------++++++++++++++++++++++X+++++++++++++++++++++----------
 02 ------++++++++++++++++++++++X+++++++++++++++++++++--------------
 03 -----++++++++++++++++++++++X++++++++++++++++++++++--------------
 04 ----++++++++++++++++++++X++++++++++++++++++++-------------------
 05 ------+++++++++++++++++++++++X++++++++++++++++++++++------------
 06 ----+++++++++++++++++++++X++++++++++++++++++++------------------
 07 ---------++++++++++++++++++++++X++++++++++++++++++++++----------
 08 -------+++++++++++++++++++++X++++++++++++++++++++---------------
 09 -------------+++++++++++++++++++++X+++++++++++++++++++++--------
 10 --------+++++++++++++++++++++X++++++++++++++++++++--------------
 11 --------------+++++++++++++++++++++X++++++++++++++++++++--------
 12 -------+++++++++++++++++++++X+++++++++++++++++++++--------------
 13 -------------++++++++++++++++++++X+++++++++++++++++++-----------
 14 -------+++++++++++++++++++++X+++++++++++++++++++++--------------
 15 ------------+++++++++++++++++++++X+++++++++++++++++++++---------
PW0
 00 ++++++++++++++++++++++++++X+++++++++++++++++++++++++------------
 01 --++++++++++++++++++++++++++X+++++++++++++++++++++++++----------
 02 +++++++++++++++++++++++++X++++++++++++++++++++++++--------------
 03 +++++++++++++++++++++++++X++++++++++++++++++++++++--------------
 04 ++++++++++++++++++++++X++++++++++++++++++++++-------------------
 05 -++++++++++++++++++++++++++X+++++++++++++++++++++++++-----------
 06 +++++++++++++++++++++++X+++++++++++++++++++++++-----------------
 07 -++++++++++++++++++++++++++X++++++++++++++++++++++++++----------
 08 ++++++++++++++++++++++++X++++++++++++++++++++++++---------------
 09 ----+++++++++++++++++++++++++X+++++++++++++++++++++++++---------
 10 +++++++++++++++++++++++++X++++++++++++++++++++++++--------------
 11 ----++++++++++++++++++++++++++X+++++++++++++++++++++++++--------
 12 +++++++++++++++++++++++++X++++++++++++++++++++++++--------------
 13 ----++++++++++++++++++++++++X++++++++++++++++++++++++-----------
 14 +++++++++++++++++++++++++X++++++++++++++++++++++++--------------
 15 ---++++++++++++++++++++++++++X+++++++++++++++++++++++++---------
NW0
 01 ----------++++++++++++++++++++++X++++++++++++++++++++++---------
 02 ------++++++++++++++++++++++X++++++++++++++++++++++-------------
 04 -----++++++++++++++++++++X+++++++++++++++++++-------------------
 07 --------+++++++++++++++++++++++X++++++++++++++++++++++----------
 08 ------++++++++++++++++++++++X+++++++++++++++++++++--------------
 09 -------------++++++++++++++++++++++X+++++++++++++++++++++-------
 10 --------+++++++++++++++++++++X+++++++++++++++++++++-------------
 11 -------------+++++++++++++++++++++X+++++++++++++++++++++--------
 12 --------+++++++++++++++++++++X+++++++++++++++++++++-------------
 13 -------------++++++++++++++++++++X++++++++++++++++++++----------
 14 --------+++++++++++++++++++++X+++++++++++++++++++++-------------
WRDQW0
 00 +++++++++++++++++++++X+++++++++++++++++++++-------+++++++++++++-
 01 ++++++++++++++++++++++X++++++++++++++++++++++------++++++++++++-
 02 +++++++++++++++++++++X+++++++++++++++++++++------++++++++++++++-
 03 +++++++++++++++++++++X++++++++++++++++++++-------++++++++++++++-
 04 +++++++++++++++++++X+++++++++++++++++++-----------+++++++++++++-
 05 ++++++++++++++++++++++X+++++++++++++++++++++-----++++++++++++++-
 06 ++++++++++++++++++++X+++++++++++++++++++----------+++++++++++++-
 07 +++++++++++++++++++++++X++++++++++++++++++++++-----++++++++++++-
 08 ++++++++++++++++++++X++++++++++++++++++++----------++++++++++++-
 09 ++++++++++++++++++++++X++++++++++++++++++++++---------+++++++++-
 10 +++++++++++++++++++++X+++++++++++++++++++++-------+++++++++++++-
 11 -++++++++++++++++++++++X+++++++++++++++++++++----------++++++++-
 12 +++++++++++++++++++++X++++++++++++++++++++-------++++++++++++++-
 13 -++++++++++++++++++++++X+++++++++++++++++++++-----------+++++++-
 14 ++++++++++++++++++++++X++++++++++++++++++++++-------+++++++++++-
 15 -++++++++++++++++++++++X+++++++++++++++++++++----------++++++++-
WRDMW0 00000021
WRDMW0 00000021
ADDR
 00 +++++++++++++++++S+++++++++++++X++++++++++++++++++++++++++++++++
CFE for Foxconn Router R8000 version: v1.0.8
Build Date: Fri May 30 15:03:06 CST 2014
Init Arena
Init Devs.
Boot up from NAND flash...
Bootcode Boot partition size = 524288(0x80000)
DDR Clock: 800 MHz
Info: DDR frequency set from clkfreq=1000,*800*
et2: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 7.14.43.2 (r474543)
CPU type 0x0: 1000MHz
Tot mem: 262144 KBytes
Device eth0:  hwaddr E8-FC-AF-F8-80-14, ipaddr 192.168.1.1, mask 255.255.255.0
Loading: Failed.
Checking crc...Loader:raw Filesys:raw Dev:nflash0.os File: Options:(null)
Loading: ... 1662344 bytes read
Entry at 0x00008000
Closing network.
Starting program at 0x00008000
Uncompressing Linux... done, booting the kernel.
Booting Linux on physical CPU 0x0
Linux version 4.4.116-rc1 ([email protected]) (gcc version 6.3.0 (LEDE GCC 6.3.0 r4639-eb43a817f7) ) #530 SMP Mon Feb 19 23:02:30 CET 2018
CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=10c5387d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: Northstar Prototype
Ignoring unrecognised tag 0x00000000
Memory policy: Data cache writealloc
map io
MPCORE found at 19020000 (VIRT 99020000) 18000000 98000000
Hit pending asynchronous external abort (FSR=0x00001c06) during first unmask, this is most likely caused by a firmware/bootloader bug.
PERCPU: Embedded 11 pages/cpu @86dd4000 s12876 r8192 d23988 u45056
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 65280
Kernel command line: console=ttyS0,115200 panic=10 root=/dev/mtdblock3 earlyprintk=1 rootfstype=squashfs,jffs2 noinitrd init=/bin/sh
PID hash table entries: 512 (order: -1, 2048 bytes)
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 254112K/262144K available (3502K kernel code, 198K rwdata, 1228K rodata, 340K init, 416K bss, 8032K reserved, 0K cma-reserved, 131072K highmem)
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
    vmalloc : 0x88800000 - 0xff800000   (1904 MB)
    lowmem  : 0x80000000 - 0x88000000   ( 128 MB)
    pkmap   : 0x7fe00000 - 0x80000000   (   2 MB)
    modules : 0x7f000000 - 0x7fe00000   (  14 MB)
      .text : 0x80008000 - 0x804a6e34   (4732 kB)
      .init : 0x804a7000 - 0x804fc000   ( 340 kB)
      .data : 0x804fc000 - 0x8052db34   ( 199 kB)
       .bss : 0x80530000 - 0x805983f4   ( 417 kB)
Hierarchical RCU implementation.
        CONFIG_RCU_FANOUT set to non-default value of 2
        Build-time adjustment of leaf fanout to 2.
NR_IRQS:256
MPCORE GIC init
soc_dmu_init
add clk lookups
MPCORE Global Timer Clock 500000000Hz on IRQ 27
sched_clock: 32 bits at 500MHz, resolution 2ns, wraps every 4294967295ns
clocksource: mpcore_gtimer: mask: 0xffffffffffffffff max_cycles: 0xe6a171a037, max_idle_ns: 881590485102 ns
register local timer
smp_twd: clock not found -2
Calibrating local timer... 499.75MHz.
Calibrating delay loop... 1987.37 BogoMIPS (lpj=9936896)
pid_max: default: 32768 minimum: 301
Security Framework initialized
Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
CPU: Testing write buffer coherency: ok
CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
2 cores has been found
Setting up static identity map for 0x85e0 - 0x8614
L2C: platform provided aux values permit register corruption.
L2C: DT/platform modifies aux control register: 0x0a130000 -> 0x7a530000
L2C-310 erratum 769419 enabled
L2C-310 enabling early BRESP for Cortex-A9
L2C-310 full line of zeros enabled for Cortex-A9
L2C-310 dynamic clock gating enabled, standby mode enabled
L2C-310 cache controller enabled, 16 ways, 256 kB
L2C-310: CACHE_ID 0x410000c8, AUX_CTRL 0x4e530001
CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
Brought up 2 CPUs
SMP: Total of 2 processors activated (3981.31 BogoMIPS).
clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
futex hash table entries: 512 (order: 3, 32768 bytes)
DMA: preallocated 256 KiB pool for atomic coherent allocations
coherence_win_size = 10000000
coherence_flag = FFFFFFF8
ddr_phys_offset_va =FFFFFFFF
ddr_phys_offset2_va =A8000000
Found a AMD NAND flash:
Total size:  128MB
Block size:  128KB
Page Size:   2048B
OOB Size:    64B
Sector size: 512B
Spare size:  16B
ECC level:   8 (8-bit)
Device ID: 0x 1 0xf1 0x80 0x1d 0x 1 0xf1
found nand nvram at 80000
CCA UART Clock Config: Sel=1 Ovr=1 Div=48
CCA UART Clock rate 125000000Hz CCB UART Clock rate 125000000Hz
clocksource: Switched to clocksource mpcore_gtimer
TCP established hash table entries: 1024 (order: 0, 4096 bytes)
TCP bind hash table entries: 1024 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 1024 bind 1024)
UDP hash table entries: 256 (order: 1, 8192 bytes)
UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
init gpio code
Netgear R8000 init
PCI: no core
PCI: no core
PCI: scanning bus 0
PCI host bridge to bus 0000:00
pci_bus 0000:00: root bus resource [io  0x0000-0xffffffff]
pci_bus 0000:00: root bus resource [mem 0x00000000-0xffffffff]
pci_bus 0000:00: root bus resource [bus 00-ff]
pci 0000:00:11.0: [Firmware Bug]: reg 0X10: invalid BAR (can't size)
PCI: Fixing up bus 0 domain 0
PCIE1 link=1
PCIE1 switching to GEN2
PCIE1 link=1
PCI host bridge to bus 0001:00
pci_bus 0001:00: root bus resource [mem 0x08000000-0x0fffffff]
pci_bus 0001:00: No busn resource found for root bus, will use [bus 00-ff]
PCI: Fixing up bus 0 domain 1
PCI: bus0: Fast back to back transfers disabled
pci 0001:01:00.0: Max Payload Size set to 512 (was 128, max 512)
PCI: Fixing up bus 1 domain 1
PCI: bus1: Fast back to back transfers disabled
pci 0001:00:00.0: BAR 8: assigned [mem 0x08000000-0x085fffff]
pci 0001:01:00.0: BAR 2: assigned [mem 0x08000000-0x083fffff 64bit]
pci 0001:01:00.0: BAR 0: assigned [mem 0x08400000-0x08407fff 64bit]
pci 0001:00:00.0: PCI bridge to [bus 01]
pci 0001:00:00.0:   bridge window [mem 0x08000000-0x085fffff]
PCIE2 link=1
PCIE2 switching to GEN2
PCIE2 link=1
PCI host bridge to bus 0002:00
pci_bus 0002:00: root bus resource [mem 0x40000000-0x47ffffff]
pci_bus 0002:00: No busn resource found for root bus, will use [bus 00-ff]
PCI: Fixing up bus 0 domain 2
PCIE: Doing PLX switch Init...Test Read = fb410003
PCIE: Doing PLX switch Init...GPIO Read = 0000003c
PCIE: Setting PEX8603 UpPort to 0dB de-emphasis.
PCIE 0002:01:0000: PLX UpPort mem_base 0x40000000, mem_limit 0x41ffffff
pci 0002:01:00.0: can't set Max Payload Size to 512; if necessary, use "pci=pcie_bus_safe" and report a bug
PCI: Fixing up bus 1 domain 2
PCIE: Doing PLX switch Init...GPIO Read = 00000000
PCIE 0002:02:0008: PLX DownPort mem_base 0x43000000, mem_limit 0x44ffffff
PCIE 0002:02:0008: PLX DownPort Link speed is GEN2
PCIE 0002:02:0008: PLX DownPort Link status 0x6012
PCIE 0002:02:0010: PLX DownPort mem_base 0x46000000, mem_limit 0x47ffffff
PCIE 0002:02:0010: PLX DownPort Link speed is GEN2
PCIE 0002:02:0010: PLX DownPort Link status 0x6012
PCI: Fixing up bus 2 domain 2
PCI: bus2: Fast back to back transfers disabled
PCI: Fixing up bus 3 domain 2
PCI: bus3: Fast back to back transfers disabled
PCI: Fixing up bus 4 domain 2
PCI: bus4: Fast back to back transfers disabled
pci 0002:00:00.0: BAR 8: assigned [mem 0x40000000-0x40cfffff]
pci 0002:00:00.0: BAR 9: assigned [mem 0x40d00000-0x40efffff 64bit pref]
pci 0002:01:00.0: BAR 8: assigned [mem 0x40000000-0x40bfffff]
pci 0002:01:00.0: BAR 9: assigned [mem 0x40d00000-0x40efffff 64bit pref]
pci 0002:01:00.0: BAR 0: assigned [mem 0x40c00000-0x40c03fff]
pci 0002:01:00.0: BAR 7: no space for [io  size 0x1000]
pci 0002:01:00.0: BAR 7: failed to assign [io  size 0x1000]
pci 0002:02:01.0: BAR 8: assigned [mem 0x40000000-0x405fffff]
pci 0002:02:02.0: BAR 8: assigned [mem 0x40600000-0x40bfffff]
pci 0002:02:01.0: BAR 9: assigned [mem 0x40d00000-0x40efffff 64bit pref]
pci 0002:02:01.0: BAR 7: no space for [io  size 0x1000]
pci 0002:02:01.0: BAR 7: failed to assign [io  size 0x1000]
pci 0002:03:00.0: BAR 2: assigned [mem 0x40000000-0x403fffff 64bit]
pci 0002:03:00.0: BAR 0: assigned [mem 0x40400000-0x40407fff 64bit]
pci 0002:02:01.0: PCI bridge to [bus 03]
pci 0002:02:01.0:   bridge window [mem 0x40000000-0x405fffff]
pci 0002:02:01.0:   bridge window [mem 0x40d00000-0x40efffff 64bit pref]
pci 0002:04:00.0: BAR 2: assigned [mem 0x40800000-0x40bfffff 64bit]
pci 0002:04:00.0: BAR 0: assigned [mem 0x40600000-0x40607fff 64bit]
pci 0002:02:02.0: PCI bridge to [bus 04]
pci 0002:02:02.0:   bridge window [mem 0x40600000-0x40bfffff]
pci 0002:01:00.0: PCI bridge to [bus 02-04]
pci 0002:01:00.0:   bridge window [mem 0x40000000-0x40bfffff]
pci 0002:01:00.0:   bridge window [mem 0x40d00000-0x40efffff 64bit pref]
pci 0002:00:00.0: PCI bridge to [bus 01-04]
pci 0002:00:00.0:   bridge window [mem 0x40000000-0x40cfffff]
pci 0002:00:00.0:   bridge window [mem 0x40d00000-0x40efffff 64bit pref]
PCIE3 link=0
squashfs: version 4.0 (2009/01/31) Phillip Lougher
io scheduler noop registered (default)
io scheduler cfq registered
serial8250_init
Serial: 8250/16550 driver, 3 ports, IRQ sharing disabled
console [ttyS0] disabled
serial8250.0: ttyS0 at MMIO 0x18000300 (irq = 117, base_baud = 7812500) is a 16550
console [ttyS0] enabled
serial8250.0: ttyS1 at MMIO 0x18000400 (irq = 117, base_baud = 7812500) is a 16550
brd: module loaded
loop: module loaded
lookup_nflash_rootfs_offset: offset = 0x200000 size = 0x2400000, 0x20000
found TRX Header on nflash!
nflash: squash filesystem with lzma found at block 29
0x000000200000-0x000002600000 : "linux"
0x0000003a0000-0x000002600000 : "rootfs"
0x000002600000-0x000002680000 : "board_data"
tun: (C) 1999-2004 Max Krasnyansky <[email protected]>
PPP BSD Compression module registered
PPP Deflate Compression module registered
GACT probability NOT on
Mirror/redirect action on
Simple TC action Loaded
netem: version 1.3
u32 classifier
    Performance counters on
    input device check on
    Actions configured
nf_conntrack version 0.5.0 (3970 buckets, 15880 max)
nf_conntrack_rtsp v0.7 loading
ip_set: protocol 6
gre: GRE over IPv4 demultiplexor driver
nf_nat_rtsp v0.7 loading
bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
Bridge firewalling registered
8021q: 802.1Q VLAN Support v1.8
Registering SWP/SWPB emulation handler
max nvram space = 131072
read 65536 bytes to offset 0
Key type encrypted registered
nand: device found, Manufacturer ID: 0x01, Chip ID: 0xf1
nand: AMD/Spansion NAND 128MiB 3,3V 8-bit
nand: 128 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
(1,1) (16,2) (32,2) (48,2) (0,0) (0,0) (0,0) (0,0) (0,0) (0,0) (0,0) (0,0) (0,0) (0,0) (0,0) (0,0) (0,0) (0,0) (0,0) (0,0) (0,0) (0,0) (0,0) (0,0) (0,0) (0,0) (0,0) (0,0) (0,0) (0,0) (0,0) (0,0)
Options: NO_SUBPAGE_WRITE,
0x000002680000-0x000008000000 : "ddwrt"
Freeing unused kernel memory: 340K
start service
starting Architecture code for northstar
cannot open /dev/nvram
udevtrigger[380]: parse_config_file: can't open '/etc/udev/udev.conf' as config file: No such file or directory
1970-01-01 00:00:06 main: Sanity checks succeeded
length = 80000
try modules for ethernet adapters
et: module license 'Proprietary' taints kernel.
et_module_init: txworkq set to 0x0
et_module_init: et_txq_thresh set to 0x400
et_module_init: et_rxlazy_timeout set to 0x3e8
et_module_init: et_rxlazy_framecnt set to 0x20
et_module_init: et_rxlazy_dyn_thresh set to 0
ET Corerev 5
eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 7.14.89.21 (r524987)
roboswitch: Probing device 'eth0'
roboswitch: trying a 53012! at eth0
detected CPU Port is 5
roboswitch: found a 53012! at eth0
wl_module_init: passivemode set to 0x0
wl_module_init: txworkq set to 0x0
PCI: Enabling device 0001:01:00.0 (0140 -> 0142)
wl driver 7.14.89.21 (r524987) failed with code 13
PCI: Enabling device 0002:03:00.0 (0140 -> 0142)
PCI: Enabling device 0002:04:00.0 (0140 -> 0142)
Netgear R8X00 workaround
[USB] checking...
umount: can't unmount /mnt: No such file or directory
eth0: mixed HW and IP checksum settings.
cannot open /proc/sys/net/ipv4/ip_conntrack_max
ifconfig: invalid hw-addr
device br0 entered promiscuous mode
CTL_set_cist_bridge_config: Got return code 0, -1
Couldn't find bridge with index 9
Couldn't change bridge bridge_forward_delay
killall: ead: no process killed
br0: Invalid argument
device vlan1 entered promiscuous mode
device eth0 entered promiscuous mode
eth1: Not supported
base addr 00:00:00:00:00:02
local bit addr 02:00:00:00:00:02
eth1: Not supported
eth1: Not supported
eth1: Operation not permitted
eth1: Not supported
nbw = 20
channel 6, val 20
C000, 1000, 0, 6
spec D006
eth1: Invalid argument
eth1: Not supported
eth1: Not supported
eth1: Not supported
eth1: Not supported
eth1: Not supported
eth1: Not supported
eth1: Not supported
eth1: Not supported
eth1: Not supported
eth1: Not supported
eth1: Not supported
eth1: Not supported
eth1: Not supported
eth1: Not supported
eth1: Not supported
eth1: Not supported
enable bss eth1 0 (1)
eth1: Not supported
eth1: Not supported
wl: Unsupported
device eth1 entered promiscuous mode
eth2: Not supported
base addr 00:00:00:00:00:03
local bit addr 02:00:00:00:00:03
eth2: Not supported
eth2: Not supported
eth2: Operation not permitted
eth2: Not supported
eth2: Invalid argument
eth2: Not supported
eth2: Not supported
eth2: Not supported
eth2: Not supported
eth2: Not supported
eth2: Not supported
eth2: Not supported
eth2: Not supported
eth2: Not supported
eth2: Not supported
eth2: Not supported
eth2: Not supported
eth2: Not supported
eth2: Not supported
eth2: Not supported
eth2: Not supported
enable bss eth2 0 (1)
eth2: Not supported
eth2: Not supported
wl: Unsupported
device eth2 entered promiscuous mode
eth3: Not supported
base addr 00:00:00:00:00:04
local bit addr 02:00:00:00:00:04
eth3: Not supported
eth3: Not supported
eth3: Operation not permitted
eth3: Not supported
eth3: Not supported
eth3: Not supported
eth3: Not supported
eth3: Not supported
eth3: Not supported
eth3: Not supported
eth3: Not supported
eth3: Not supported
eth3: Not supported
eth3: Not supported
eth3: Not supported
eth3: Not supported
eth3: Not supported
eth3: Not supported
eth3: Not supported
eth3: Not supported
eth3: Invalid argument
enable bss eth3 0 (1)
eth3: Not supported
eth3: Not supported
wl: Unsupported
device eth3 entered promiscuous mode
sh: ead: br0: port 4(eth3) entered forwarding state
notbr0: port 4(eth3) entered forwarding state
 fobr0: port 3(eth2) entered forwarding state
undbr0: port 3(eth2) entered forwarding state
br0: port 2(eth1) entered forwarding state
br0: port 1(vlan1) entered forwarding state
device br0 left promiscuous mode
ifconfig: ioctl 0x8914 failed: Address not available
function start_hwmon not found
device vlan2 entered promiscuous mode
cp: can't stat '/tmp/mycron.d/*': No such file or directory
cp: can't stat '/jffs/mycron.d/*': No such file or directory
cp: can't stat '/mmc/mycron.d/*': No such file or directory
random: dnsmasq: uninitialized urandom read (128 bytes read, 78 bits of entropy available)
random: dnsmasq: uninitialized urandom read (48 bytes read, 78 bits of entropy available)
cat: can't open '/proc/sys/net/netfilter/nf_conntrack_flush': No such file or directory
cannot open /proc/net/arp_spoofing_enable
device vlan2 left promiscuous mode
udhcpc: started, v1.28.0
udhcpc: sending discover
Radio: 0 currently turned off
Radio: 1 currently turned off
radio_off(1) interface: eth2
Radio: 2 currently turned off
Duplicate configuration request
/opt/etc/init.d/rcS: No such file or directory
/jffs/etc/init.d/rcS: No such file or directory
/mmc/etc/init.d/rcS: No such file or directory
rmmod: eoip: No such file or directory
eth2: Not supported
eth2: Not supported
eth2: Not supported
eth2: Not supported
eth2: Not supported
eth2: Not supported
eth2: Not supported
eth2: Not supported
eth2: Not supported
eth2: Not supported
eth2: Not supported
eth2: Not supported
eth2: Not supported
eth2: Not supported
eth2: Not supported
eth2: Not supported
eth2: Not supported
eth2: Not supported
eth2: Not supported
eth2: Not supported
eth2: Not supported
killall: proxywatchdog.sh: no process killed
random: nas: uninitialized urandom read (16 bytes read, 122 bits of entropy available)
/mnt/smbshare
umount: can't unmount /mnt/smbshare: No such file or directory
rmmod: cifs: No such file or directory
rmmod: fscache: No such file or directory
killall: schedulerb.sh: no process killed
killall: shatd: no process killed
killall: wdswatchdog.sh: no process killed
The Milkfish Router Services
ERROR: Necessary service setting not found: milkfish_username - aborting.
eth2: Nrandom: nonblocking pool is initialized
ot supported
Restoring SIP ddsubscriber database from NVRAM...
Empty.
Restoring SIP ddaliases database from NVRAM...
Empty.
radio_on(1) interface: eth2
wl: wl driver adapter not found
eth2: Not supported
eth3: Not supported
Usage: ntpclient <server> [server [...]]
process_monitor..done
michelle911
I've tried everything and can
I've tried everything and can get no communication with the router and got no other suggestions, so I'm throwing it in the garbage!
Alex0597
Keep Crt pressed and
Keep Crt pressed and repeatedly press c when booting up the router, that will put you in the CFE. Then you can run the commands that u want.
Alex0597
crtl*
crtl*
goryglory
HEllo Experts
HEllo Experts
I seem cant enter CFE. Tried 4 hours now before psoting here. Ctl C repeadely and contionous doe not lets me break in via Putty
here is the output
SHMOO VER 1.13
S300001CF
000012D0
RDLYW0 00000004
RDENW0 00000035
RDQSW0
 00 -----+++++++++++++++++++++++++X++++++++++++++++++++++++---------
 01 -------+++++++++++++++++++++++++X++++++++++++++++++++++++-------
 02 -----++++++++++++++++++++++++X++++++++++++++++++++++++----------
 03 -----++++++++++++++++++++++++X+++++++++++++++++++++++-----------
 04 ---+++++++++++++++++++++++X+++++++++++++++++++++++--------------
 05 ------+++++++++++++++++++++++++X++++++++++++++++++++++++--------
 06 ----++++++++++++++++++++++X++++++++++++++++++++++---------------
 07 --------+++++++++++++++++++++++++X++++++++++++++++++++++++------
 08 -----+++++++++++++++++++++X++++++++++++++++++++-----------------
 09 ----------+++++++++++++++++++++++X+++++++++++++++++++++++-------
 10 -----++++++++++++++++++++++++X+++++++++++++++++++++++-----------
 11 ----------+++++++++++++++++++++++X+++++++++++++++++++++++-------
 12 ---+++++++++++++++++++++++X+++++++++++++++++++++++--------------
 13 ----------++++++++++++++++++++++X++++++++++++++++++++++---------
 14 -----+++++++++++++++++++++++X++++++++++++++++++++++-------------
 15 -----------+++++++++++++++++++++++X+++++++++++++++++++++++------
PW0
 01 --------+++++++++++++++++++++++++X++++++++++++++++++++++++------
 02 ----+++++++++++++++++++++++++X++++++++++++++++++++++++----------
 04 ---++++++++++++++++++++++++X+++++++++++++++++++++++-------------
 06 ----+++++++++++++++++++++++X++++++++++++++++++++++--------------
 08 -----+++++++++++++++++++++X+++++++++++++++++++++----------------
 09 ----------+++++++++++++++++++++++++X++++++++++++++++++++++++----
 11 ----------+++++++++++++++++++++++++X++++++++++++++++++++++++----
 12 ---+++++++++++++++++++++++++X++++++++++++++++++++++++-----------
 13 ----------++++++++++++++++++++++++X+++++++++++++++++++++++------
 14 ------++++++++++++++++++++++++X+++++++++++++++++++++++----------
 15 -----------+-+++++++++++++++++++++++X+++++++++++++++++++++++----
NW0
 00 --++++++++++++++++++++++++++X++++++++++++++++++++++++++---------
 01 ----++++++++++++++++++++++++++X++++++++++++++++++++++++++-------
 02 --++++++++++++++++++++++++++X+++++++++++++++++++++++++----------
 03 -+++++++++++++++++++++++++X+++++++++++++++++++++++++------------
 04 +++++++++++++++++++++++++X++++++++++++++++++++++++--------------
 05 --+++++++++++++++++++++++++++X++++++++++++++++++++++++++--------
 06 -++++++++++++++++++++++++X+++++++++++++++++++++++---------------
 07 ----+++++++++++++++++++++++++++X++++++++++++++++++++++++++------
 08 +++++++++++++++++++++++X+++++++++++++++++++++++-----------------
 09 ----++++++++++++++++++++++++++X++++++++++++++++++++++++++-------
 10 ++++++++++++++++++++++++++X++++++++++++++++++++++++++-----------
 11 -----++++++++++++++++++++++++++X+++++++++++++++++++++++++-------
 13 ----++++++++++++++++++++++++++X+++++++++++++++++++++++++--------
 14 +++++++++++++++++++++++++X+++++++++++++++++++++++++-------------
 15 -----++++++++++++++++++++++++++X++++++++++++++++++++++++++------
WRDQW0
 00 +++++++++++++++++++++++X+++++++++++++++++++++++-----+++++++++++-
 01 +++++++++++++++++++++++X+++++++++++++++++++++++-------+++++++++-
 02 +++++++++++++++++++++++X+++++++++++++++++++++++------++++++++++-
 03 +++++++++++++++++++++++X+++++++++++++++++++++++-----+++++++++++-
 04 +++++++++++++++++++++X+++++++++++++++++++++---------+++++++++++-
 05 +++++++++++++++++++++++X+++++++++++++++++++++++------++++++++++-
 06 +++++++++++++++++++++X+++++++++++++++++++++---------+++++++++++-
 07 ++++++++++++++++++++++++X+++++++++++++++++++++++-------++++++++-
 08 ++++++++++++++++++++++X++++++++++++++++++++++-------+++++++++++-
 09 -+++++++++++++++++++++++X+++++++++++++++++++++++-----------++++-
 10 ++++++++++++++++++++++++X+++++++++++++++++++++++------+++++++++-
 11 --+++++++++++++++++++++++X++++++++++++++++++++++-----------++++-
 12 +++++++++++++++++++++++X++++++++++++++++++++++------+++++++++++-
 13 -+++++++++++++++++++++++X+++++++++++++++++++++++---------++++++-
 14 +++++++++++++++++++++++X+++++++++++++++++++++++-------+++++++++-
 15 -+++++++++++++++++++++++X+++++++++++++++++++++++----------+++++-
WRDMW0 00000022
WRDMW0 00000023
ADDR
 00 ++++++++++++++++++S++++++++++++X++++++++++++++++++++++++++++++++
Init Arena
Init Devs.
DDR Clock: 800 MHz
Device eth0:  hwaddr 9C-3D-CF-08-EB-F8, ipaddr 192.168.1.1, mask 255.255.255.0
Loading: Failed.
Loading: ..... 4982560 bytes read
Entry at 0x00008000
Closing network.
console [ttyS0] enabled, bootconsole disabled
brd: module loaded
loop: module loaded
nflash: squash filesystem with lzma found at block 31
Creating 17 MTD partitions on "nflash":
0x0000003eef20-0x000002600000 : "rootfs"
0x000002680000-0x000002780000 : "POT1"
0x000002780000-0x000002880000 : "POT2"
0x000002880000-0x000002b40000 : "T_Meter1"
0x000002b40000-0x000002e00000 : "T_Meter2"
0x000002e00000-0x000002e80000 : "ML1"
0x000002e80000-0x000002f00000 : "ML2"
0x000002f00000-0x000002f80000 : "ML3"
0x000002f80000-0x000003000000 : "ML4"
0x000003000000-0x000003080000 : "ML5"
0x000003080000-0x000003100000 : "ML6"
0x000003100000-0x000003180000 : "ML7"
0x000003180000-0x000003200000 : "QoSRule"
PPPoL2TP kernel driver, V0.17
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ehci_hcd 0000:00:0b.1: EHCI Host Controller
ehci_hcd 0000:00:0b.1: new USB bus registered, assigned bus number 1
ehci_hcd 0000:00:0b.1: irq 111, io mem 0x18021000
ehci_hcd 0000:00:0b.1: USB 0.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
ohci_hcd 0000:00:0b.0: OHCI Host Controller
ohci_hcd 0000:00:0b.0: new USB bus registered, assigned bus number 2
ohci_hcd 0000:00:0b.0: irq 111, io mem 0x18022000
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
xhci_hcd 0000:00:0c.0: xHCI Host Controller
xhci_hcd 0000:00:0c.0: new USB bus registered, assigned bus number 3
xhci_hcd 0000:00:0c.0: irq 112, io mem 0x18023000
xhci_hcd 0000:00:0c.0: Failed to enable MSI-X
xhci_hcd 0000:00:0c.0: failed to allocate MSI entry
usb usb3: No SuperSpeed endpoint companion for config 1  interface 0 altsetting 0 ep 129: using minimum values
xHCI xhci_add_endpoint called for root hub
xHCI xhci_check_bandwidth called for root hub
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 1 port detected
csw_retry 100
Initializing USB Mass Storage driver...
USB Mass Storage support registered.
u32 classifier
    Actions configured
nf_conntrack version 0.5.0 (3979 buckets, 15916 max)
TCP cubic registered
NET: Registered protocol family 10
lo: Disabled Privacy Extensions
IPv6 over IPv4 tunneling driver
sit0: Disabled Privacy Extensions
ip6tnl0: Disabled Privacy Extensions
NAND device: Manufacturer ID: 0x01, Chip ID: 0xf1 (AMD NAND 128MiB 3,3V 8-bit)
Options: NO_AUTOINCR,NO_READRDY,BBT_SCAN2NDPAGE,
Creating 2 MTD partitions on "brcmnand":
0x000003200000-0x000007b00000 : "brcmnand"
0x000007b00000-0x000008000000 : "OpenVPN"
SQUASHFS error: Xattrs in filesystem, these will be ignored
devtmpfs: mounted
Freeing init memory: 220K
[sighandler]: No more events to be processed, quitting.
[cleanup]: Waiting for children.
[cleanup]: All children terminated.
Reading board data...
WSC UUID: 0x038dd0da63e4a5b53b5ec953410bb969
NTP synchronized date/time: Sun Jan 25 07:49:12 2004
MAC address of 1st STA connected: 4C-BB-58-D5-53-37
No RF parameters! Use default.
### main:1520 Set Normal Power!
Initialise conn table 2048 entries
SHMOO VER 1.13
S300001C7
000012B0
RDLYW0 00000004
RDENW0 00000035
RDQSW0
 01 --------++++++++++++++++++++++++X++++++++++++++++++++++++-------
 03 -----+++++++++++++++++++++++X+++++++++++++++++++++++------------
 05 -------++++++++++++++++++++++++X++++++++++++++++++++++++--------
 06 ----++++++++++++++++++++++X+++++++++++++++++++++----------------
 12 ----+++++++++++++++++++++++X+++++++++++++++++++++++-------------
 14 ------++++++++++++++++++++++X++++++++++++++++++++++-------------
 15 ------------+++++++++++++++++++++++X++++++++++++++++++++++------
PW0
 01 --------+-+++++++++++++++++++++++X+++++++++++++++++++++++-------
 06 ------++++++++++++++++++++++X+++++++++++++++++++++--------------
 08 ----++++++++++++++++++++++X+++++++++++++++++++++----------------
 09 -----------++++++++++++++++++++++++X++++++++++++++++++++++++----
 10 ------+++++++++++++++++++++++X+++++++++++++++++++++++-----------
 11 -----------++++++++++++++++++++++++X++++++++++++++++++++++++----
 15 ------------++++++++++++++++++++++++X+++++++++++++++++++++++----
NW0
 00 -+++++++++++++++++++++++++++X++++++++++++++++++++++++++---------
 02 -++++++++++++++++++++++++++X++++++++++++++++++++++++++----------
 05 -+++++++++++++++++++++++++++X+++++++++++++++++++++++++++--------
 06 -+++++++++++++++++++++++X+++++++++++++++++++++++----------------
 11 ----++++++++++++++++++++++++++X++++++++++++++++++++++++++-------
 15 ------+++++++++++++++++++++++++X+++++++++++++++++++++++++-------
WRDQW0
 02 +++++++++++++++++++++++X+++++++++++++++++++++++-----+++++++++++-
 08 ++++++++++++++++++++++X++++++++++++++++++++++--------++++++++++-
WRDMW0 00000022
WRDMW0 00000023
ADDR
Init Arena
Init Devs.
DDR Clock: 800 MHz
Loading: Failed.
Entry at 0x00008000
Closing network.
brd: module loaded
loop: module loaded
csw_retry 100
u32 classifier
    Actions configured
devtmpfs: mounted
NTP synchronized date/time: Sat Feb  7 17:48:40 2004
Please help. Its an R8000 router
goryglory
HEllo Experts
HEllo Experts
here is the output
SHMOO VER 1.13
S300001CF
000012D0
RDLYW0 00000004
RDENW0 00000035
RDQSW0
PW0
NW0
WRDQW0
WRDMW0 00000022
WRDMW0 00000023
ADDR
Init Arena
Init Devs.
DDR Clock: 800 MHz
Loading: Failed.
Entry at 0x00008000
Closing network.
brd: module loaded
loop: module loaded
csw_retry 100
u32 classifier
    Actions configured
devtmpfs: mounted
SHMOO VER 1.13
S300001C7
000012B0
RDLYW0 00000004
RDENW0 00000035
RDQSW0
PW0
NW0
WRDQW0
WRDMW0 00000022
WRDMW0 00000023
ADDR
Init Arena
Init Devs.
DDR Clock: 800 MHz
Loading: Failed.
Entry at 0x00008000
Closing network.
brd: module loaded
loop: module loaded
csw_retry 100
u32 classifier
    Actions configured
devtmpfs: mounted
