- I think the R8000 firmware 5 days 7 hours ago
- Just want to add some update: 1 week 1 hour ago
- When I press Ctrl+C, the boot 1 week 3 hours ago
- Well, Netgear has the 1 week 1 day ago
The link is:
The link is:
Hello Voxel,
Thanks in advance.
Start/stop Plex:
Voxel,
Hi.
Sorry for my poor english.
Yeah, I know. See above.
The link is:
opkg update
Collected errors:
Danser
From WIKI:
for details.
The link is:
The link is:
Changes (vs 1.0.4.30HF):
The link is:
Changes (vs 1.0.4.31.1HF):
8. zlib package is optimized.
The link is:
Changes (vs 1.0.4.32HF):
1. QoS DB is updated to v1.58
The link is:
