MyOpenRouter.com is not affiliated with NETGEAR®. NETGEAR is a registered trademark of NETGEAR, Inc. in the United States and/or other countries. Other brand names mentioned herein are for identification purposes only and may be trademarks of their respective holder(s). © 2020 All rights reserved.
The link is:
The link is:
Hello Voxel,
Thanks in advance.
Start/stop Plex:
Voxel,
Hi.
Sorry for my poor english.
Yeah, I know. See above.
The link is:
opkg update
Collected errors:
Danser
From WIKI:
for details.
The link is:
The link is:
Changes (vs 1.0.4.30HF):
The link is:
Changes (vs 1.0.4.31.1HF):
8. zlib package is optimized.
The link is:
Changes (vs 1.0.4.32HF):
1. QoS DB is updated to v1.58
The link is:
