Hi, I just installed Voxel firmware 1.0.2.59SF
Due to the recent modify the entware now is different, no default path set so (I don't know why Voxel make this decision, certainly he has good reason), so like he suggested, I created /root/.profile and I put
export PATH=/opt/bin:/opt/sbin:$PATH
into it.
Now the opkg update works great, I only have one problem after one or 2 installation I got this error
root@
R7800:~$ opkg update
Collected errors:
* opkg_conf_load: Could not create lock file /opt/var/lock/opkg.lock: Read-only file system.
Seems that the partition are full, am I right?
Here the mounts:
rootfs on / type rootfs (rw)
/dev/root on /rom type squashfs (ro,relatime)
proc on /proc type proc (rw,relatime)
sysfs on /sys type sysfs (rw,relatime)
tmpfs on /tmp type tmpfs (rw,nosuid,nodev,relatime,size=0k)
tmpfs on /dev type tmpfs (rw,relatime,size=512k,mode=755)
devpts on /dev/pts type devpts (rw,relatime,gid=5,mode=620)
none on /proc/bus/usb type usbfs (rw,relatime)
ubi0:overlay_volume on /overlay type ubifs (rw,relatime)
overlayfs:/overlay on / type overlayfs (rw,relatime,lowerdir=/,upperdir=/overlay)
debugfs on /sys/kernel/debug type debugfs (rw,relatime)
/dev/sda1 on /tmp/mnt/sda1 type ext4 (ro,nodev,relatime,data=writeback)
tmpfs on /hipplay/TMP type tmpfs (rw,nosuid,nodev,relatime,size=0k)
tmpfs on /hipplay/dev type tmpfs (rw,relatime,size=512k,mode=755)
proc on /hipplay/proc type proc (rw,relatime)
tmpfs on /hipplay/etc type tmpfs (rw,nosuid,nodev,relatime,size=0k)
tmpfs on /hipplay/home/0db type tmpfs (rw,nosuid,nodev,relatime,size=0k)
tmpfs on /hipplay/var/lib/sqlite type tmpfs (rw,nosuid,nodev,relatime,size=0k)
tmpfs on /hipplay/tmpHost type tmpfs (rw,nosuid,nodev,relatime,size=0k)
tmpfs on /hipplay/tmp type tmpfs (rw,nosuid,nodev,relatime,size=0k)
tmpfs on /hipplay/home/0external type tmpfs (rw,nosuid,nodev,relatime,size=0k)
/dev/sda1 on /hipplay/home/0external/0698e899-581d-9142-b421-0d7fb6692829 type ext4 (ro,nodev,relatime,data=writeback)
devpts on /hipplay/dev/pts type devpts (rw,relatime,gid=5,mode=620)
tmpfs on /hipplay/dev/shm type tmpfs (rw,relatime,mode=777)
I don't know if is all normal but I only created a .profile into root dir, I don't have rebooted the router, not yet
Here the df output:
Filesystem 1k-blocks Used Available Use% Mounted on
tmpfs 512 0 512 0% /dev
ubi0:overlay_volume 51032 11076 37316 23% /overlay
overlayfs:/overlay 51032 11076 37316 23% /
/dev/sda1 7709624 159152 7158844 2% /tmp/mnt/sda1
tmpfs 512 0 512 0% /hipplay/dev
/dev/sda1 7709624 159152 7158844 2% /hipplay/home/0external/0698e899-581d-9142-b421-0d7fb6692829
tmpfs 241760 0 241760 0% /hipplay/dev/shm
Here the opt folder, if help:
drwxr-xr-x 6 root root 1.2k Jun 1 09:08 .
drwxr-xr-x 1 root root 816 Sep 2 03:28 ..
lrwxrwxrwx 1 root root 25 Sep 1 23:11 bin -> /tmp/mnt/sda1/entware/bin
-rw-r--r-- 1 root root 175 Aug 27 19:04 dirlist
lrwxrwxrwx 1 root root 25 Sep 1 23:11 etc -> /tmp/mnt/sda1/entware/etc
-rw-r--r-- 1 root root 855 Aug 27 19:04 filelist
lrwxrwxrwx 1 root root 26 Sep 1 23:11 home -> /tmp/mnt/sda1/entware/home
drwxr-xr-x 2 501 20 224 Aug 27 19:04 leafp2p
lrwxrwxrwx 1 root root 25 Sep 1 23:11 lib -> /tmp/mnt/sda1/entware/lib
drwxr-xr-x 4 501 20 648 Aug 27 19:04 rcagent
drwxr-xr-x 2 501 20 296 Jul 19 2017 remote
lrwxrwxrwx 1 root root 26 Sep 1 23:11 root -> /tmp/mnt/sda1/entware/root
lrwxrwxrwx 1 root root 26 Sep 1 23:11 sbin -> /tmp/mnt/sda1/entware/sbin
lrwxrwxrwx 1 root root 27 Sep 1 23:11 share -> /tmp/mnt/sda1/entware/share
lrwxrwxrwx 1 root root 25 Sep 1 23:11 tmp -> /tmp/mnt/sda1/entware/tmp
lrwxrwxrwx 1 root root 25 Sep 1 23:11 usr -> /tmp/mnt/sda1/entware/usr
lrwxrwxrwx 1 root root 25 Sep 1 23:11 var -> /tmp/mnt/sda1/entware/var
-rw-r--r-- 1 root root 45 Aug 27 19:04 version
drwxr-xr-x 3 501 20 504 Aug 27 19:04 xagent
Any idea or help?
Thanks in advance
J
I Installed from scratch entware, so I formatted an usb stick into ext4 labeled optware, then I plugged it!
I used the instruction from FAQ_entware_instaliations.txt from the site so at first impression works, but after one day I've a problem the partition is mounted as read only and is strange, no reboot or nothing, nothing that I've commanded!
Any idea?
