Good morning. I am new to using DD-WRT and was wondering if there is a tutorial on how to set DD-WRT up in a Netgear R8000 X6 router. I was able to flash my router with no issue's, but was not able to access the internet. My Imac is getting both WIFI names, but again no access to the Internet. Any help would be useful. Running DD-WRT_r8000_30180531 from this sight.
You’ll prolly have to change your LAN IP Address and then all would be good.
Are you talking about the gateway IP or the router IP?
Under dd-wrt set up change your lan ip to 10.0.0.1, that should do the trick.
