DD-WRT tutorial for setup
5 posts / 0 new
2pfspiff
2pfspiff's picture
Good morning.  I am new to using DD-WRT and was wondering if there is a tutorial on how to set DD-WRT up in a Netgear R8000 X6 router.  I was able to flash my router with no issue's, but was not able to access the internet.  My Imac is getting both WIFI names, but again no access to the Internet.  Any help would be useful.  Running DD-WRT_r8000_30180531 from this sight.
Alex0597
Alex0597's picture
You’ll prolly have to change
You’ll prolly have to change your LAN IP Address and then all would be good.
2pfspiff
2pfspiff's picture
Are you talking about the
Are you talking about the gateway IP or the router IP?
Alex0597
Alex0597's picture
Under dd-wrt set up change
Under dd-wrt set up change your lan ip to 10.0.0.1, that should do the trick.
2pfspiff
2pfspiff's picture
