R7000 on tomato 3.5-140 problem with ipv6
2 posts / 0 new
DANIEL BYRNS
DANIEL BYRNS's picture
Now I the stock netgrear firmware I could get ipv6 by setting to auto detect. I wish I wrote down the setting.
I have switch to the newest advanced tomato due to the stock netgrear would freeze a lot or loose 5 ghz of slow internet.
So far tomato works great but would like ipv6 to work like it did. I was able to follow the firmware change pretty easy but also did a search for my isssue. The problem is I could not follow what the heck they were talking about .
So if someone has gotten this to work could you please send screen shot of how you did it.
Thanks for all replys
DANIEL BYRNS
Okay it will work if i set to
Okay it will work if i set to 6to4 anycast relay for the life can not get dhcpv6 with prefix delegation. Any ideas would be great
