Hi
I have been using this router for sometime with no issues, the problem i've come across is that i'm having some issues with openvpn, I have spoken to some people who uses Tomato Builds and tell me that they have no problems using vpn with the same setup. for that I would like to flash from DD-WRT v3.0-r30600M kongac (09/09/16) to Tomato builds
all advice on what version and files that I will need will be apreciated
Regards
Rob
Go back to OFW, download the initial file for Advanced tomato, erase the nvram and then flash the full version.
Thank you for your reply Alex
I have looked throughout the forum and canot find the files that take me back to OFW
I have found for tomato to OFW but not DD-WRT to OFW, some sort of guide is appreciated
Regards
To bring to it's official firmware do I just upload the R8000 Chk file and then the OFW firmware?
Regards
To go back from DD WRT to OFW just go to Netgear’s website download the latest firmware and just flash it regularly, wait 2 minutes after the flash and turn the router off then on. That should get you to OFW. Advanced Tomato is different cuz is a .trx file thats why u need a Back to OFW firmware.
followed instructions how to revert back to OFW and all OK
once in OFW did a reset, uploaded tomato Chk File, OK did a reset and then uploaded trx file, Problem
Router on boot loop!
any help appreciated
Regards
Disconnect all the cables exept power and let it boot. If it doesn’t work press the reset bottom fomr 10 sec, that should do the trick.
None of the above worked
Get all the clables out of the router, especially the wan cable. Plug just the power, let the router fully boot up and then connect all the other cables.
