- R8000P would be grate to see. 1 year 14 hours ago
- Have a R8000 but ordered a 1 year 14 hours ago
In order to setup VPN client connection on your router, it has to support at least one of these connection types: PPTP, L2TP or OpenVPN. Furthermore, it has to support it as a "Client" (as opposed to a "Server") this is what NordVPN is saying. Is there something here that will accomplish all of this?
Thanks again
Yes I use it with my R9000 as the client. Works ok. Performance is so-so. About 40mb download and 10 upload on a 300mb connection. Not great but it serves the purpose. The OpenVPN client in the router is not the best...
I am using NordVPN on a Netgear R7000 flashed with Tomato.
I two VPN connections running on the router under client 1 (in country) and 2 (in another country)
It words quite good.
The NordVPN have good instructions for routers running flashed firmware and their help was very good with some connection tweaking.
I'm still trying to figure out the reason of having to go through this for NordVPN. Is there any good reason and see is flashing with Tomato any better than DD-WRT?
