I am totally new to this, (never even heard of dd-wrt 2 weeks ago), but I flasked my r7000p successfully, but I dont have 5gband only 2.4. How do I configure the router to show both (or at least select one or the other).
Thanks in advance
Thanks in advance
I'm having the same problem. Have tried a few builds but no 5G wireless on any DD-WRT builds that I've tried. Have tried switching channels to no avail.
Would you both please provide the firmware versions you have used? Thanks
33770 is the current build. Sorry, didn't make note of the other 2, but one is what's up on the current K3-AC-ARM for R7000P.
: DD-WRT v3.0-r37900M (12/03/18) on a R7000P I just bought, 5g working on that.....this is a test build
Everything been good on that build so far? Just mainly wanting VPN on the router and all my wired and wireless to work. Thanks for the tip.
Yes, so far both wireless working....
Working well here. I only used the .chk file, no .bin.
I had this problem too. I've ended up going back to NG Genie.
Some datapoints:
Apparently my router automatically updated itself to 39960 and the 5GHz physical interface stopped showing on dd-wrt the control panel. I tried moving up to 40270 and the 5GHz started showing up again, however I was unable to connect to it. I tried resetting to factory defaults with no luck as well. I've now moved down to 37900 and am able to connect to 5GHz. Thanks pb1983!!
For reference, I found the firmwares here: http://ddwrt-kong.clonevince.fr/
I am running DD-WRT v3.0-r43381 build and its working here as well. But i did have issues with the early 3k builds
