r6700 kong build taking a long time rebooting?
5 posts / 0 new
Firestw152
Whenever I click on reboot router in the ddwrt browser it takes a very long time to come back on its almost like its stuck in a bootloop sometimes it takes as long as 15 minutes to fully reboot and for me to have internet access again. Why is this happening, do I have a bad flash or maybe I have some settings not right?
I click reboot router and then it looks like its turning off and on again for multiple minutes before it fully turns on again. Any advice would be great.
Fictitiousexistence
This happens to me too on an
This happens to me too on an R6400. It usually takes 15 minutes on a reboot or upgrade.
I just upgraded to the April version and have been waiting reboot after reboot for over half an hour.
It reboots, shows I have internet, and then reboots again.
Fictitiousexistence
Right after I posted it
Right after I posted it finally came back to life. Took 36 minutes and a good chunk of my sanity.
marc@louisville...
What version / build are you
What version / build are you guys running?
bradymcm
Any update on this issue? I
Any update on this issue? I'm running the latest Kong build for R6400 from 5-31-18 and have this exact issue.
Thanks in advance.
