I have been using Voxel's excellent firmware and I am grateful for this.
The only problem I have (and I had the same issue with the stock firmware, regardless of version) is with QoS.
The main issue is that when I choose a priority for a connected device, set it and save, when I click again, it is set back to what it was (usually to low). As such I cannot change the priority which renders the whole point of QoS null.
Additionally, since after I installed Voxel's firmware, the router cannot do a speed test anymore. I click to start, and everything is greyd out.
Any help (mainly for the former issue) would be great. The problem is so large that when my server (whom I want at lowest priority) downloads files (cloud backups/restores) my Smart TV (which I want at highests) pauses playback from BBC iPlayer and only resumes if I stop the server. This should not be happening.
Thank you.
You might post about this here:
https://www.snbforums.com/forums/netgear-ac-wireless.53/
In my opinion, you should check carefully one more time you will find out where the problem you are having.
GoMovies
