- I think the R8000 firmware 1 day 19 hours ago
- Just want to add some update: 3 days 13 hours ago
- When I press Ctrl+C, the boot 3 days 15 hours ago
- Well, Netgear has the 5 days 11 hours ago
- waste of time 1 month 2 weeks ago
The link is:
1. uhttpd: Fix for Attached Device Names is included (similar to r7800).
The link is:
Hello Voxel,
Thanks in advance.
Start/stop Plex:
Voxel,
Hi.
Sorry for my poor english.
Yeah, I know. See above.
The link is:
opkg update
Collected errors:
Danser
From WIKI:
(NOTE: This release does not contain integration of latest stock firmware changes. Too many negative feedback (issues) for release of the stock firmware. But there are several fixes of security issues so it has a sense to perform upgrade from previous version. Thus it is intermediate maintenance release to provide synchronization of changes for r7800.)
for details.
The link is:
The link is:
Changes (vs 1.0.4.30HF):
The link is:
Changes (vs 1.0.4.31.1HF):
8. zlib package is optimized.
The link is:
Changes (vs 1.0.4.32HF):
1. QoS DB is updated to v1.58
The link is:
