Chromecast doesn't work with DD-WRT v3.0-r36070M firmware
2 posts / 0 new
pastim
pastim's picture
I installed this version, but it still doesn't support Chromecast. The Web admin GUI is also very, very. slow.
The last version that worked seems to have been v3.0-r32170M.  I went back to that and it still works.  I have not changed any settings.
I like to keep fairly up to date with firmware, but am currently unable to do so with DD WRT.  Is there some extra trick required to get Chromcast to work on later versions of DD WRT?
rick1221
rick1221's picture
dcccac
The issue with the firmware update is still there and by the post, I can understand how the Chromecast is not working. The GUI has to be supported to the module and then I have also faced the same. I was not being able to connect to the latest version as well.
