I am using the R7800 with the Voxel image behind a fritzbox cable router. I only managed it to use the ovpn client within the Voxel image if I am using the R7800 as type router. But now I have double NAT. Is there any option to use the R7800 with the ovpn client in Bridge or AP mode to avoid the double NAT?
Thx
https://www.edpnet.be/en/support/installation-and-usage/internet/manage-fritz!box/how-to-set-up-an-exposed-host-on-a-fritzbox.html
https://en.avm.de/service/fritzbox/fritzbox-7390/knowledge-base/publication/show/131_Setting-up-a-DMZ-with-the-FRITZ-Box/
