R7000 Update - won't accept most firmwares
23 posts / 0 new
SAK
I've been flashing the R7000 routers for quite some time now - never an issue.  Recently I purchased a few brand new units on Amazon.  These new units refuse to accept the DD-WRT Kong firmware (I tried latest 2 versions).  They even refuse to accept most of the old Netgear factory firmwares except for the 3-4 of the most recent ones.
I was able to get Tomato on there and then XWRT-Vortex.  But for the life of me I cannot get DD-WRT Kong on these new units.  I tried TFTP, I tried checking and re-writing the board_id (it was already set at the correct value).  Nothing is making the router accept DD-WRT :(
Anyone have any ideas?  This is so frustrating.
SAK
I seem to now be stuck on
I seem to now be stuck on XWRT-Vortex R7000_384.8_2
I can't flash to anything else from within the XWRT-Vortex admin page.
SAK
Invalid Firmware Upload
Firmware upgrade unsuccessful. This might result from incorrect image or error transmission, please check the model name R7000 and version of firmware from support site and try again.
nguilhot
Hi SAK,
Maybe you could try flashing your router using nmrpflash https://github.com/jclehner/nmrpflash.
Regards
mrdon213
There are NEW Freshtomato
There are NEW Freshtomato init files for this router. Try that one and let me know if it works, if it does not, a screenshot of the failure would be greatly appreciated.
SAK
I tried the latest
I tried the latest FreshTomato initial firmware - freshtomato-R7000-2019.2-initial-64K.chk
It takes.  From inside there I tried to flash to dd-wrt.K3_R7000_20180531 - it acts like it is flashing - the first time it acted like it worked, but after the router rebooted - it was still FreshTomato.  The second time - I get this error: /tmp/flashEBE3Hd: Bad trx header
SAK
Offering a $75 bounty if
Offering a $75 bounty if anyone can help me find a way to get these new routers to flash reliably.  This is such a headache.
I tried nmrpflash - I wasn't able to get that to work.  It always times out after uploading the firmware file.
I have one router stuck on XWRT-Vortex - can't get anything else on it.  I was successful at getting Tomato onto one router, which will fit my use I suppose...better than nothing...and on another router it won't budge from Netgear Firmware V1.0.9.34_10.2.36 - it just gives the error "This firmware file is incorrect! Please get the firmware file again and make sure it is correct firmware for this product." - no matter which firmware I try (freshtomato initial, dd-wrt, any other version of netgear firmware, vortex, etc)
mrdon213
Do factory reset on routers.
Do factory reset on routers. (with power on use toothpick or something similar to press reset button for 10 seconds).
Then on freshtomato router try flashing full freshtomato then dd-wrt. make sure erase NVRAM is checked both times.
On router stuck on V1.0.9.34 try to upgrade to newer or older stock firmware. Then try migrating to Freshtomato or DD-WRT.
No idea about XWRT-Vortex I dont use closed source firmware, they should have method of reverting to stock.
Jandatec
It seems like the the new
It seems like the the new President of Netgear is a true NICE GUY??  I spoke with a person from netgear support admin who wanted to go off the record and this has to do not only with image size but with file signatures.  They have basically done the same thing Samsung did with Android and their hardware only from a different direction.  They claim the EULA specifically says, you are just have a use license on the OS and firmware and they will not allow ANY third party anything.  I have a big problem with this and plan to get up in the NICE GUYS FACE AT THE NEXT CES/VEGAS.
mesteele101
Come, be reasonable. There
Come, be reasonable. There are HUNDREDS if not more that have bricked their router by installing third party firmware. I don't think that Netgear should be responsible for this, and I really don'tr think you do...
mrdon213
Hundreds if not more have
Hundreds if not more have BRICKED there routers using NETGEARS built in updater also. There is a risk no matter how a router is updated and it has to be to avoid internet threats. Read and follow instructions carefully and you too can be like the thousands that HAVE NOT BRICKED there router.
SAK
The new routers will take
The new routers will take freshtomato, but still nothing else.  I've tried the resets to no avail.  I will try again when I get some new ones in.  I've been making use with Tomato - I had to get units into the field so I was able to get by.  Hopefully it runs stably.
The only problem remains is that I have 2 routers with XWRT-Vortex and can't get it off of there.  It won't take absolutely anything except XWRT-Vortex firmwares at this point.  So I would highly recommend for now until a fix is found for people to avoid flashing THAT firmware onto their new R7000s
SAK
Apparently the XWRT-Vortex
Apparently the XWRT-Vortex software is illegal to use with Netgear routers.  It allegedly contains proprietary software without license.  If I had known this, I wouldn't have flashed it.  I hope I don't have 2 bricks now.  They are cool looking but expensive decorations.
Merlin says it's illegal, so I would advise everyone against using that for this reason too, not to mention you might get stuck on it.  Who ported this over for Netgear routers?  I wonder if they might know how to get it off again.
mrdon213
Here is a link for vortex
Here is a link for vortex back to stock. I dont know if you have tried this one yet.
 https://mega.nz/#!B80j2RDR!mf-c_6SrWKodtQYCP6iw_FxyJ52XlRffkF3Nyb-41GQ
From there you should be able to flash either dd-wrt or Freshtomato.
I do not have a R7000 to test on so just doing the best I can to help.
SAK
Aha - that one worked for the
Aha - that one worked for the router stuck on vortex!  Thank you, mrdon!
That router still wouldn't take DD-WRT though.  But I'm putting Tomato on it right now.
The other router is stuck on factory 1.0.9.34, but I'm going to keep trying resets and different firmwares to see if anything will take
mrdon213
Good, Now for the one stuck
Good, Now for the one stuck on 1.0.9.34 there are 3 updates after that. Have you tried loading them, From stock firmware in a reset condition it should ask you to update the firmware to a newer version, Let it update if it does. Then try to flash Fresh tomato.
I will get back to you on Freshtomato to dd-wrt
mrdon213
You should be able to
You should be able to directly Flash DD-WRT from freshtomato. This should be the link to KONG'S latest build.
https://www.myopenrouter.com/sites/default/files/downloads/dd-wrt.K3_R70...
djk44883
Have you sucsuffly installed
Have you sucsuffly installed dd-wrt?  I hade the same struggleing issue.  Installed XWRT-Vortex - got stuck with it.  Discovered "back to stock". and started over with inital flash files.  When I installed dd-wrt, it would reset with eash reboot - wouldn't save settings.  I'm not certain it ever has a complet factory reset, unless it now comes with a default wireless security turned on with a passphrase (maybe), since mine does.
I have installed fresh-tomato with no real issues, still I don't thing I should have ever left dd-wrt after many years - it doesn't really matter what it looks like.
mrdon213
DD-WRT last time I checked,
DD-WRT last time I checked, KONG builds come with wireless turned ON and the Passphrase is the factory default one on the sticker. You should be able to directly flash DD-WRT from tomato or freshtomato. Make sure to erase nvram before and after flashing! I dont have a R7000 to verify but works on my R8000 and that part of the code is the same on both.
djk44883
Thanks for the wifi password
Thanks for the wifi password note!  I had used "stock" dd-wrt firmware on older firmware.  Yes, R7000 has default on label (duh), sorry.  Ok, so that's not an issue.   I haven't gotten back to it... every time I rebooted it would ask for new user/pass as though it was reset.
I had read some where another had a similar issue.  I had been trying to populate static leases, I know if you get a character out of place it can cause odd results.  Not to claim I know exactly what I'm doing, I've been flashing and using dd-wrt since a wrt-54g, so I have some clue.  But, yes it takes one little thing to flubed it all up
Thanks for all your input and support!!
sailorjh
Newbe to using dd-wrt was
Newbe to using dd-wrt was able to update to DD-WRT v3.0-r37305 std (10/10/18) on my R7000.  I would like to get a more recent firmware.  I have tried
dd-wrt.v24-K3_AC_ARM_R7000P.bin and others but no go.  Any guidance will be appreciated.
5L4FK0
You downloaded wrong version,
You downloaded wrong version, it is for R7000P, not for R7000...
elvskerm
hey mate, did you manage to
hey mate, did you manage to solve this? i'm having the exact same issue.  thanks
