So after exploring the world of ddwrt, I decided I wanted to go back to stock due to speed issues (I couldn't figure out how to get the full speed out of ddwrt. I tried just flashing the firmware from netgear, but it kept failing. I stumbled upon the link below in a previous post and it worked great!....
http://desipro.de/ddwrt/K3-AC-IPQ806X/NetgearFW/
I am definitely rocking stock firmware now, but somehow in that process the login has changed to something other than what I have previously set it as, and what the router is typically stock. I have tried to a hard reset, and even tried letting it update the firmware in hopes it would ask me to do it then, but I am still blocked out of it.
I am not sure how to telnet into my router, but I am fairly confident it would require credentials (which I do not have), therefore figured I would post my issue here while I continued searching for the answer.
Any help is much appreciated!
Search ended quicker than expected, sorry for the wasted post! If this happens to anyone else try the login below:
Username: superadmin
Password: password
Also can't edit posts it seems, I am definitely sorry for the spam, correction below:
Username: superuser
Password: password
