We shouldn't have to go down the rabbit hole like this not everyone who uses DD-WRT wants to risk a serial connection especially when the router is under warrenty and the screws are under the sticker .....
Shit i got the same error, this is a pain in the ass. I have tried everything and since 3 months now i've been fucking around that router to flash it with dd wrt. Does someone know a solution which is not too complicated??
This needs to be resolved it cant be that hard to release a new initial flash packge with updated board id's and version numbers to match the genie's version check
Or you can flash a pre-patched version of OpenWRT which allows you to then use whatever firmware you wish to. A link to it is about half way down the page on the DD-WRT forums. Can confirm it worked on mine.
Just got the router today and flashed it using this method. But with some modifications...
1. Flash openwrt-bcm53xx-netgear-R8000-squashfs.chk in DD-WRT using Netgear web gui.
2. ssh into the router with
Code:
ssh root@192.168.1.1
There is no password so you'll go right in.
3. Plug a network cable from your existing router/cable modem/etc that provides DHCP address leases into the WAN port and use ifconfig to check until you see one of the ports pick up a DHCP address. You can do that with
Code:
ifconfig
4. Assuming you get an IP and can get to the internet (
Code:
ping 8.8.8.8
from the ssh prompt will tell you) at this point we need to install and enable the web interface
Code:
opkg update (had to keep rerunning to get all the packages down)
opkg install luci (had to keep rerunning to get the install complete)
/etc/init.d/uhttpd start
/etc/init.d/uhttpd enable
mv /etc/config/luci.bak /etc/config/luci (added by me)
/usr/lib/lua/luci/dispatcher.lua:247: /etc/config/luci seems to be corrupt, unable to find section 'main'
stack traceback:
[C]: in function 'assert'
/usr/lib/lua/luci/dispatcher.lua:247: in function 'dispatch'
/usr/lib/lua/luci/dispatcher.lua:144: in function </usr/lib/lua/luci/dispatcher.lua:143>
attempted a few fixes and ended up with a boot looping router. waiting on a serial cable to ship now any ideas whats going on here ?
but THIS is exactly the reason kong needs to release a pached dd-wrt too many potential points of failure with a roundabout instalation method like this
There are new Init files for Freshtomato that should work.
https://forum.dd-wrt.com/phpBB2/viewtopic.php?t=315110&postdays=0&postorder=asc&start=30
Code:
Code:
ifconfig
Code:
ping 8.8.8.8
Code:
5. If that worked you can access the device with http://192.168.1.1
factory reset (added buy me)
http://192.168.1.1/start.htm (if you get the luci screen which I did)
http://192.168.1.1/index.asp (I had to explicitly add index.asp as the default was going to the Luci themed interface
6. Go through the initial setup prompts and then flash your http://www.desipro.de/ddwrt/K3-AC-Arm/dd-wrt.K3_R8000.chk firmware. Power cycle the device and you should be able to access it via http://192.168.1.1 with DD-WRT working as expected. Maybe should use the .bin
LUCI failed to install with
stack traceback:
