Voxel Firmware to Netgear R9000 Stock
3 posts / 0 new
wazapar
Can anyone point me to the img download that I can use to get my R9000 back to Stock Netgear Firmware.
EventHorizon
If you look in the DDWRT Kong
If you look in the DDWRT Kong R9000 firmware packages he includes a rollback image for the stock firmware which would probably work. But that has not been updated since the beginnning of the year so you will likely be going backwards a bit before you can go forward. Why reverting to vanilla anyway?
edan
Would that file work even
Would that file work even though it is a .bin? I believe that stock firmware as well as Voxel's fw is working with .img files.
