R7000: Tomato or DD-WRT? Kong or BrainSlayer?
9 posts / 0 new
Aqualung
Aqualung's picture
Fed up with NetGear's stock FW stumbles (60, 64, 88). Please advise as to what open source FW would be the best.
Many thanks!
Aqualung
djk44883
djk44883's picture
To say which is the best would suggest others are bad.  The best is what works for you or suits your needs.  Generally they are all great.
I had generally been happy with Kong's dd-wrt but am currently running fresh tomato since Xwrt-Vortex apprently damaged my router - don't use xwrt-vortex
garryweil
garryweil's picture
A few months ago I saw that
A few months ago I saw that Kong was no longer doing any updates for R7000. Is this still true?
5L4FK0
5L4FK0's picture
Not even remotly true.
The releases in the past did overwrite routers CFE, however now this is not the case anymore. It is necessary to flash CFE in the begining, so you have to make a backup of your original one at first. But then, in my experience, this is by far the best firmware there is possible to flash on R7000.
But...
Because it is a port of ASUS/Merlin firmware it is not really "legal", so no support for your further questions here or on SMB forum... Further info can be found on Xvortex homepage.
djk44883
djk44883's picture
All you gott'a do is click
All you gott'a do is click onthe Download link at the top...  choose R7000 from the dropdown list [suprise]
DD-WRT Kong Mod for NETGEAR R7000P (2019-04-03) 4/3/19 DD-WRT for R7000/R7000P
djk44883
djk44883's picture
If past releases did
If past releases did overwrite CFE, then wouldn't it be at least remotely true?  ...if not completly?
There was no mention "so you have to make a backup of your original one at first"
The firmware wan't terrible, but in my experience, not "by far" great :(  considering it overwrote my CFE - it's absolutly shamful!  Sadlly disapointed I can no longer run dd-wrt :(
sc00terx
sc00terx's picture
Hi all  ,I have a brnad new
Hi all  ,I have a brand new R7000  i can not send it back as  i have had it over 3 months but do not like what netgear have done to the fw    - dlna  and so on  to add  something that  you  pay them  £70 ish  a year for  so  i need  to  get a new FW  for my   R7000  still got the  shiny rap on  hmm  :(
sowhatFW out of them above  is a easy install    TY  for any info as ever  sc00terx
mrdon213
mrdon213's picture
You CAN run DD-WRT. DD-WRT
You CAN run DD-WRT. DD-WRT never overwrote the CFE. The only firmware that overwrote the CFE was Xvortex. Xvortex is a ILLEGAL Firmware. You have No access to source code, and it uses modules Licensed only to ASUS on Netgear routers.
Use DD-WRT or Freshtomato, they both have there strong and weak points, I have used both.
djk44883
djk44883's picture
"Use DD-WRT or Freshtomato,
"Use DD-WRT or Freshtomato, they both have there strong and weak points, I have used both."
That's how not one it necessarily better.  Different points for differnt users needs.
