extender or repeater mode
5 posts / 0 new
minutech
I wanted to use my R6400 as an extender.
I read that the only way to do that was with dd-wrt.
I flashed it, the router rebooted, I see the software, but I do not see extender listed anywhere in any tab.
was I duped into believing this would make a router that does not normally extend into an extender?
i don't like to be duped.. wasted time I think.
Please advise.
Thank you,
Christina
TSpin
I have the same question. I'm
I have the same question. I'm hoping that dd-wrt will allow the R6400v1 to be configured as a repeater. But I'm thinking it may be a function of the Broadcom BCM4708A0 chip that's in the router. If anyone has a definate answer, please post.
mrdon213
There are instructions to do
There are instructions to do this in the DD-WRT Wiki. It is a function of the firmware not the hardware,
Quick google search turned up many step by step instructions, here is one link,there are many others.
https://proprivacy.com/guides/how-use-an-old-dd-wrt-router-as-a-repeater
pb1983
did you use any of the
did you use any of the instructions for repeater or client bridge?
TSpin
Thanks mrdon213. I'll load
Thanks mrdon213. I'll load Kong on it and let everyone know if it gives me the ability to configure it as a repeater.
