- After the initial Kong Mod 5 months 2 days ago
- Working the EXACT same 5 months 2 days ago
- R8000P would be grate to see. 5 months 2 weeks ago
- Have a R8000 but ordered a 5 months 2 weeks ago
Hello, Voxel
I have a R7800 working together with a EX8000 (Nighthawk X6S) Extender as a Mesh Network.
Both updated to their latest original Netgear Firmware.
Would things still work, and even better, if I upgraded my R7800 with your Firmware.
Do you know of a similar upgrade for the EX8000 (Or do you maybe plan to make one?)
IF it works, don't fix it. Youl can update to Voxels FW. However again, if things are working well, don't bother it.
Voxel doesn't have any FW for the EX extender models. I don't believe there are any plans as he doesn't work on extenders nor has an extender to work with. Usually nothing is really needed on Extenders. They work or they don't. They only work as well as the main host router does. The EX 8000 and 7700 are solid working extenders.
Hi everyone,
I've been using Voxel's firmware for a long time now on my R7800 and I love it. But I just upgraded my Internet service from a 50mbit to 100mbit line.
Curiously, I get 100mbit with the stock firmware and no VPN connection. On Voxel's firmware I only get 57mbit without and 23mbit with an OpenVPN client connection. That is way too slow. I'm using NordVPN and they can do much higher speeds, also the R7800 hardware is capable of doing more than 23mbit. I wouldn't complain if I got 75mbit, due to the encryption overhead, but 23-27mbit on average it pretty slow.
Any suggestions?
It is really too slow. I have 200/200Mbit real connection (198/190 reported by speedtest) and about 110/70Mbit for speed using OpenVPN (connected to my remote server). Check your opvn config. Best result if using AES-128-CBC and lz4_v2 (if NordVPN supports this).
Try to play with ovpn settings (your ovpn config). Maybe sndbuf/rcvbuf. I set it to 0 (system defaults).
Good to know, thanks. Nordcom doesn't seem to support anything below AES-256-CBC, but I'll check the other settings.
This is my current config, anything you would change, except for the encryption level?
auth SHA512
Also, maybe it's not in the openVPN settings, because I get only half the speed of my connection using the VPN-bypass, where I should get full speed as the routing goes directly through to the gateway router. So something in the Netgear config is slowing it down.
First you should resolve the problem with your limited speed w/o OpenVPN. You should have real 100Mbit. Maybe backup settings->factory reset->restore settings.
In your config. I do not use NordVPN. But good service should push optimal options itself (pushing them).
I would play with (testing after resolving your limited speed w/o OpenVPN):
1. Removing any tun-mtu, tun-mtu-extra, mssfix from ovpn and from /etc/init.d/openvpn-client (line OPT_ARGS="--dev tun21 --fast-io --nice -20 ...")
2. Playing with sndbuf/rcvbuf. Starting from setting them to zero (i.e. to use system defaults). The same modification of /etc/init.d/openvpn-client
3. "comp-lzo" -> compress lz4-v2
4. remote-random - I'd select concrete server, what is faster for your location.
5. AES-256-CBC. In general AES-128-GCM provides the same level of security (OpenVPN 2.4.x). And at least (if not supported by OpenVPN server) AES-256-GCM works much faster on Intel-based servers. CBC - serial operations. GCM could be performed with parallelization. So CBC->GCM as a test.
P.S.
GCM:
see e.g. https://www.privateinternetaccess.com/helpdesk/kb/articles/what-s-the-difference-between-aes-cbc-and-aes-gcm
Hey Voxel,
thank you for your helpful reply. I've played around with a few settings and also change Wifi Channels on the router, which might have helped.
As you said, most settings get pushed from the server and there is only so much I can change. For example, I do get AES-256-GCM, even if I try 128 in the config. But it does seem to accept the optimized compression setting. I now get 37mbit, which is a great improvement, though still far from the speed I would expect.
I also restored to factory settings and then imported the saved settings from backup, which didn't really change anything.
I read somewhere that Netgear is now offering an openVPN client on the stock firmware, but only a few vpn providers (strange). Have you seen this and have you made any speed tests with the regular stock firmware?
Also, I recently tested Wireguard with NordVPN and it's really really fast, though still in development. Do you think that could be implemented in your firmware? It looks like that could be an openVPN alternative for some use cases, like watching Netflix etc, because it's so fast.
Best,
Randy
Hello Voxel,
On your this website I see R7800-V1.0.2.67SF.img as the latest release.
However on your website I already find R7800-V1.0.2.67.1SF.img.
Can we consider the last one a stable release?
Yes.
See https://www.snbforums.com/threads/custom-firmware-build-for-r7800-v-1-0-2-67sf-1-0-2-67-1sf.56921/
Voxel
Kamoj intends to release his add-on with OpenVPN handling including NordVPN.
https://www.snbforums.com/threads/poll-for-openvpn-provider-to-be-supported-by-voxel-firmware.56627/
No. I do not think it is fast. And really as far as I know single provider is supported.
I am not sure it is possible. Wireguard requirements: kernel >= 3.10. NG is using modified 3.4.103. My own changes on the level of kernel are troublesome because of possible incompatibility with kernel objects from NG pre-built binaries (in their GPL).
Wow, that sounds great and I see the NordVPN is in the lead... :-)
DD-WRT supports Wireguard and I think there is a version for the R7800 out there, I just would prefer to stick with your firmware, as DD-WRT's openVPN implementation is not specific to the router and therefore is not as fast. So maybe there is a way...just saying ;-)
BTW, try the following options to get AES-128-GCM:
and check OpenVPN client log re: what cipher is used now. IMO it should speed up.
Thanks, I just tried that. But I still only get 35Mbit/s...strange. Here's the log:
Wed Jul 3 14:42:52 2019 OpenVPN 2.4.7 arm-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD]
Wed Jul 3 14:42:52 2019 library versions: OpenSSL 1.1.1c 28 May 2019, LZO 2.10
Wed Jul 3 14:42:52 2019 WARNING: --ping should normally be used with --ping-restart or --ping-exit
Wed Jul 3 14:42:52 2019 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Wed Jul 3 14:42:52 2019 Outgoing Control Channel Authentication: Using 512 bit message hash 'SHA512' for HMAC authentication
Wed Jul 3 14:42:52 2019 Incoming Control Channel Authentication: Using 512 bit message hash 'SHA512' for HMAC authentication
Wed Jul 3 14:42:52 2019 nice -20 succeeded
Wed Jul 3 14:42:52 2019 TCP/UDP: Preserving recently used remote address: [AF_INET]104.222.153.29:1194
Wed Jul 3 14:42:52 2019 Socket Buffers: R=[212992->212992] S=[212992->212992]
Wed Jul 3 14:42:52 2019 UDP link local: (not bound)
Wed Jul 3 14:42:52 2019 UDP link remote: [AF_INET]104.222.153.29:1194
Wed Jul 3 14:42:53 2019 TLS: Initial packet from [AF_INET]104.222.153.29:1194, sid=4d0c38b3 f96378d9
Wed Jul 3 14:42:53 2019 VERIFY OK: depth=2, C=PA, O=NordVPN, CN=NordVPN Root CA
Wed Jul 3 14:42:53 2019 VERIFY OK: depth=1, C=PA, O=NordVPN, CN=NordVPN CA3
Wed Jul 3 14:42:53 2019 VERIFY KU OK
Wed Jul 3 14:42:53 2019 Validating certificate extended key usage
Wed Jul 3 14:42:53 2019 ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
Wed Jul 3 14:42:53 2019 VERIFY EKU OK
Wed Jul 3 14:42:53 2019 VERIFY OK: depth=0, CN=us2676.nordvpn.com
Wed Jul 3 14:42:53 2019 WARNING: 'link-mtu' is used inconsistently, local='link-mtu 1582', remote='link-mtu 1634'
Wed Jul 3 14:42:53 2019 WARNING: 'cipher' is used inconsistently, local='cipher AES-128-GCM', remote='cipher AES-256-CBC'
Wed Jul 3 14:42:53 2019 WARNING: 'auth' is used inconsistently, local='auth [null-digest]', remote='auth SHA512'
Wed Jul 3 14:42:53 2019 WARNING: 'keysize' is used inconsistently, local='keysize 128', remote='keysize 256'
Wed Jul 3 14:42:53 2019 Control Channel: TLSv1.2, cipher TLSv1.2 ECDHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
Wed Jul 3 14:42:53 2019 [us2676.nordvpn.com] Peer Connection Initiated with [AF_INET]104.222.153.29:1194
Wed Jul 3 14:42:54 2019 SENT CONTROL [us2676.nordvpn.com]: 'PUSH_REQUEST' (status=1)
Wed Jul 3 14:42:54 2019 PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1,dhcp-option DNS 103.86.96.100,dhcp-option DNS 103.86.99.100,sndbuf 524288,rcvbuf 524288,explicit-exit-notify,comp-lzo no,route-gateway 10.8.8.1,topology subnet,ping 60,ping-restart 180,ifconfig 10.8.8.51 255.255.255.0,peer-id 43'
Wed Jul 3 14:42:54 2019 OPTIONS IMPORT: timers and/or timeouts modified
Wed Jul 3 14:42:54 2019 OPTIONS IMPORT: explicit notify parm(s) modified
Wed Jul 3 14:42:54 2019 OPTIONS IMPORT: compression parms modified
Wed Jul 3 14:42:54 2019 OPTIONS IMPORT: --sndbuf/--rcvbuf options modified
Wed Jul 3 14:42:54 2019 Socket Buffers: R=[212992->425984] S=[212992->425984]
Wed Jul 3 14:42:54 2019 OPTIONS IMPORT: --ifconfig/up options modified
Wed Jul 3 14:42:54 2019 OPTIONS IMPORT: route options modified
Wed Jul 3 14:42:54 2019 OPTIONS IMPORT: route-related options modified
Wed Jul 3 14:42:54 2019 OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
Wed Jul 3 14:42:54 2019 OPTIONS IMPORT: peer-id set
Wed Jul 3 14:42:54 2019 OPTIONS IMPORT: adjusting link_mtu to 1657
Wed Jul 3 14:42:54 2019 Outgoing Data Channel: Cipher 'AES-128-GCM' initialized with 128 bit key
Wed Jul 3 14:42:54 2019 Incoming Data Channel: Cipher 'AES-128-GCM' initialized with 128 bit key
Wed Jul 3 14:42:54 2019 TUN/TAP device tun21 opened
Wed Jul 3 14:42:54 2019 TUN/TAP TX queue length set to 1000
Wed Jul 3 14:42:54 2019 /sbin/ifconfig tun21 10.8.8.51 netmask 255.255.255.0 mtu 1500 broadcast 10.8.8.255
Wed Jul 3 14:42:54 2019 /etc/openvpn/ovpnclient-up.sh tun21 1500 1585 10.8.8.51 255.255.255.0 init
RTNETLINK answers: File exists
Wed Jul 3 14:42:54 2019 /sbin/route add -net 104.222.153.29 netmask 255.255.255.255 gw 192.168.1.1
Wed Jul 3 14:42:54 2019 /sbin/route add -net 0.0.0.0 netmask 128.0.0.0 gw 10.8.8.1
Wed Jul 3 14:42:54 2019 /sbin/route add -net 128.0.0.0 netmask 128.0.0.0 gw 10.8.8.1
Wed Jul 3 14:42:54 2019 Initialization Sequence Completed
Timings from kamoj (NordVPN):
Interesting, thank you for sharing. I also get 37 with and 75 without OpenVPN, using NordVPN and 256-CBC. I wasn't able to get anything beyond 50, which is a shame, considering I'm paying for 100mbit and getting less than half.
That's why I thought Wireguard would help. It's incredibly fast and NordVPN is currently testing it in Beta, but I suspect they will soon offer it as a regular service alongside OpenVPN, IPSec etc.
Voxel FW easy gives 100+ Mbps. Maximum seems to be around 120 Mbps at 256-CBC.
I have tried several VPN providers, like PIA and NordVPN, and done 100:s of tests.
The important things is to find the best server to connect to.
I'm working on an add-on to Voxel FW, that checks server load, bandwidth and ping times to find a good server.
NordVPN today:
AES-256-CBC-mssfix1450: min/mean/max (of 100+ tests)
DL=47861/70071/107437 (Kbps)
Sounds great. I always connect to a specific server in the U.S., which of course means that it's slower when there are a lot of people on the server. So auto-selection would be great. When do you expect to release the add-on?
End of August - maybe.
I'm working on 3 add-ons simultaeously + adaptions needed to work with Voxel FW (rewritten openvpn-client),
and mainatain compatibility with R9000/R8900 as well.
I'm working too much including travelling away from home and then no router to test with.
Then I need to squeeze in some vacation...
Probably I'll first release the revamped "debug addon" as a separate add-on, to get feedback asap about the new interface.
Thank you for your interest!
Wow, very cool, sounds amazing. Let me know if you need a tester :-)
New version of my custom firmware build: 1.0.2.68SF.
Changes (vs 1.0.2.67.1SF):
1. Kernel vulnerability: CVE-2019-11477, CVE-2019-11478, CVE-2019-11479 are fixed:
2. unbound package (used in stubby) is upgraded 1.9.1->1.9.2.
3. yaml package (used in stubby) is upgraded 0.2.1->0.2.2.
4. libjson-c package is upgraded 0.12.1->0.13.1.
5. liblz4 package is upgraded 1.8.3->1.9.1.
6. util-linux package is upgraded 2.33.1->2.34.
7. sysstat package is upgraded 11.6.4->12.0.5.
8. gdbm package is upgraded 1.11->1.18.1.
9. uClibc: sync with GNU C library patch is added.
10. zlib package is optimized.
11. ReadyCLOUD install script is changed (cosmetic changes).
12. Host tools: three components are upgraded (bison, mpfr, scons).
The link is:
New version of my custom firmware build: 1.0.2.69SF.
Changes (vs 1.0.2.68SF):
1. libreadline: fixing read-only attribute for target libraries to provide strip of binary (saving space).
2. amule, libcrypto++, wxWidgets: optimization of size (saving space).
3. libunistring is removed (not needed, saving space).
4. libogg is removed (not needed, saving space).
5. Transmission: change of GUI. transmission-web-control package is added and standard transmission-web package is removed.
6. OpenSSL package: unification of Makefile (identical with R9000 version).
7. lz4 package: unification of Makefile (identical with R9000 version).
8. lzo package: unification of Makefile (identical with R9000 version).
9. OpenVPN package: unification of Makefile (identical with R9000 version).
10. dropbear package: unification of Makefile (identical with R9000 version).
12 libflac package optimization (sync with OpenWRT version).
13. curl package is upgraded 7.65.1->7.65.3.
14. expat package is upgraded 2.2.6->2.2.7.
15. sqlite package is upgraded 3270200->3290000.
16. Host tools: two components are upgraded (e2fsprogs, scons).
The link is:
Hi, does this still work for the R7800 ? I flashed with V1.0.2.68SF, but cannot get it going. I am able to telnet, but it does not recgonize the inserted flash drive. Well, I can see the drive in gui, but not in telnet. I need to set this for openvpn.
I read the readme.docx, but because I cannot use the USB, there is not much I can do.
What "this"?
BTW Latest FW version is 1.0.2.69SF.
And why do you think that your flash drive is not recognized? Check the command from telnet:
df
does it display attached drive? What is a filesystem?
Voxel
Thank you for your reply Mr. Voxel. I did updgrade to the latest firmware. I was able to get SSH going. OpenVPN, I have to do it manually each time /etc/init.d/openvpn start. I'd love to have it auto, but I have no problem with manual if there is no auto way.
How do I set the script so that it drops the connection if openvpn stops working? I do not see that option in readme.docx
I am still going through the readme.docx and other online resources. I may have more questions later. Thank you for this fine firmware Mr Voxel and others who helped to make it better
Of course it should start automatically. So something is wrong. BTW I understand that you mean OpenVPN client? I.e. "/etc/init.d/openvpn-client start". Right?
There is such script: /etc/openvpn/ovpnclient-down.sh. Now it just sets WAN LED to orange. You can modify it for your needs.
You are welcome,
Hi Voxel,
For some reason I had to rollback firmware from 1.0.2.69SF to 1.0.2.66SF. Unfortunately Transmission UI from newer version remained and does not work properly. Is there any way to restore old Transmission UI?
What concrete problem with new GUI for Transmission? I cannot say that I am using it very often. But did not face any problems.
People rather like it
and there was a request to add exactly new GUI
New version of my custom firmware build: 1.0.2.70SF.
Changes (vs 1.0.2.69SF):
1. proftpd package is upgraded from specific version with NG changes to 1.3.6 + CVE-2019-12815 security patch.
(Plus some changes in its behavior. Issue alarmed by kamoj)
2. DNSCrypt Proxy v.2 is upgraded 2.0.25->2.0.27 (Firefox workaround).
3. OpenSSL v. 1.0.2 package is upgraded 1.0.2s->1.0.2t.
(see https://www.openssl.org/news/openssl-1.0.2-notes.html for details)
4. OpenSSL v. 1.0.2 package: patch to strip cflags from resulting binary is added.
5. OpenSSL v. 1.1.1 package is upgraded 1.1.1c->1.1.1d.
(see https://www.openssl.org/news/openssl-1.1.1-notes.html for details)
6. haveged package is upgraded 1.9.4->1.9.6.
7. uci package is upgraded 2019-05-17->2019-09-01.
8. unbound package (used in stubby) is upgraded 1.9.2->1.9.3.
9. libgcrypt package is upgraded 1.8.4->1.8.5.
10. libcharset package is removed (not needed, saving space).
11. Duplication of old/new versions of libyaml package is fixed.
The link is:
The problem resolved by itself. It was a browser error. The old UI returned after the downgrade. Nevertheless, I liked the new UI very much but I can't use it. That's because newer firmware versions (with new UI) for some reason don't want to connect to the trackers. The problem occurs with and without SLL on various trackers. Now I'm using 1.0.2.66SF and this is last version without tracker connection problems.
