http://www.desipro.de/dd-wrt/Notice.txt
Desipro shut down the file share for the dd-wrt kong mod file shares without warning. After seeing this, I immediately decided to go to openwrt due to the dropped update support; however, the stock firmware bin images were also taken down. Now I am trapped on a dd-wrt build with no way to go back to stock, or otherwise. Does anyone have a mirror for these files?
I'm actually very upset this was handled this way and I feel like a mirror should have been offered instead of the terrible notice.txt to give end users a way to move off the firmware. I want control back over my device.
I have the same problem. Does someone know of a site where we could download the correct file to restore our routers to factory condition?
I just found this link on another part of the site - thanks to Markg999 for posting it.
https://www.myopenrouter.com/download/netgear-r9000-nighthawk-x10-stock-...
The link posted by kshap82 is for the R9000 nighthawk (not R7800) - does anyone have a copy of KONG's "ddwrt-to-netgear-fw-R7800.bin" file which was removed along with all the other files on the www.desipro.de/dd-wrt website?
Hi to all,
this is the link to firmware for R7800.
https://mega.nz/#!M0pzFYrT!aDHQMr0PhhXpz3kQKKzVVPvWHATQ-it1ew3Y4cYMnhg
Regards
Thanks for the link - it's too bad the restoration firmware also disappeared when KONG shut down his repository but this does the job!
Home boy getting involved in the HK protest movement that is why.
Also I bet none of you sent a donation to him. If you contribute, I bet he will cough up another build for you.
Dig deep, $100 minimum, things is expensive these days.
Also I could use a build too, so you contribute, and I will download and help with test, after the beta stage.
