Easy telnet enable on R6400 with Netgear fw
2 posts / 0 new
tweakradje
tweakradje's picture
If you want to enable telnet on the stock R6400 just point your browser to http://<router IP>/debug.htm and select telnet
Telnet to your device and voila. No username and password. Maybe you can enable ssh now for better security.
It will be disabled again after reboot.
Cheers
myk
myk's picture
This doesn't seem to work
This doesn't seem to work anymore.  The HTML and JS are commented out.  I tried to "Edit As HTML" with Chrome, but that didn't seem to work.  Anybody have other suggestions?
