Hi all,
I've successfully setted up Entware on my R7800 and installed with /opt/bin/opkg lighttpd web server.
Using rc.unslung to start the service at the boot i discover that lighttpd don't start, there was another instances of lighttpd running, doing a 'rc.unslung restart' the service start correctly ...
Any info about the lighttpd instances already running on the router (it's running before autorun/scripts/post-mount.sh is started)? ... is it really necessary? ...
Thanks in advance for your support.
Stefano
Hi all,
solved !!
If ReadyShare is active and HTTP protocol is enable, an istance of lighttpd exist to support this functionality.
If ReadyShare over HTTP is disable everithig is working fine.
-STefano
