R7800 version and dd-wrt
2 posts / 0 new
nkaufman
Recently got a R7800 and have the following questions.
(1) Some posts had mentioned that the version of the router needs to be one that can have dd-wrt installed. The box I got does not say anything on router version. I guess I'll need to open the box and check the actual router to figure that.
Once I open the box, what versions of this router is compatible with dd-wrt?
(2) What version of dd-wrt should one install?
from the one on dd-wrt site or the one from this site?
pros, cons of the above 2 installs?
spy
You can install dd-wrt, kong
