Hi folks!
I cannot establish the IEEE 802.3ad connection after configuring the R9000 with Voxel's FW. It worked properly with stock FW. Any thoughts, suggestions? Anyone else having the same issue? I've found posts mentioning that link aggregation is not supported on the Kong DD-WRT FW but no information about it with Voxel's FW.
I have made motifications to the FW according to Voxel's readme along with some corrections according to other forum discussions on this site (very helpful). Mainly just to establish an OVPN connection on R9000 power cycle, followed by bypassing the NAS's IP on the VPN connection.
SSH Configured, Entware installed
Info:
Netgear X10 R9000 on Voxel V1.0.4.31HF
Link aggregation bond being attemped with a Synology NAS DS918+ running DSM 6.2.2-24922 Update 2 with Both systems seem stable.
-E
link aggregation:
Sorry: cannot test this. Will be checked when I have necessary equipment.
Hi Voxel,
I've got the same issue.
Static Link Aggregation works.Dynamic IEEE 802.3ad is not working.
I'm connecting a R9000 to a Netgear GS724T
I'm using the latest firmaware R9000-V1.0.4.42HF.
regards
Luis Meira
Hi Again,
I'll be happy to help you test this if needed.
regards
Luis Meira
BTW it is working now. With my latest FW.
