- After the initial Kong Mod 7 months 5 days ago
- Working the EXACT same 7 months 5 days ago
- While the "5 Easy Steps" 7 months 2 weeks ago
- R8000P would be grate to see. 7 months 2 weeks ago
- Have a R8000 but ordered a 7 months 2 weeks ago
Hey,
Policy based routing and tomato on R7000
I just switched from DD-WRT to tomato. Mainly because I wanted to try it but I was getting the reboots with DD-WRT that annoyed me.
It works and I was able to get it to work with PIA VPN without a hitch. The VPN seems faster, however I can't get policy based routing to work. With the VPN on my VoIP phone won't work. Without policy based routing or a way to exempt my phone I will have to go back. DD-WRT has a nice section for policy based routing that made it a snap.
I tried this to get it working without success ( it seems to work for a while after the router reboots. )
Administration > Scripts > WAN Up
ip route add default table 100 via x.x.x.x
ip rule add fwmark 1 table 100
ip route flush cache
iptables -t mangle -I PREROUTING -i br0 -s 192.168.x.x/32 -j MARK --set-mark 1
x.x.x.x = ISP gateway
192.168.x.x/32 = IP I don't want to use the VPN
Used this guide to get VPN working with PIA
https://www.privateinternetaccess.com/forum/index.php?p=/discussion/110/...
As far as I could see, Genie is no longer working with R7000P.
I have the Firmare Version V10301.64_10.136. How shall I proceed in order to install Tomato?
Thanks in advance
Thanks in advance
Currently there is no support for the R7000P on tomato.
Hopefully soon!
