Any support for the ac750 r6020 router? Picked one up cheap but can not find information about it. If you need any more information on it let me know.
Thank You.
Hi aurorazero, I have the same router and don't have a solution yet. Did you find one?
-Brad
i have one too i need the dd-wrt fimware on itif you have one can you send it to me
