Hello All,
I have flashed the R8000 with R7000 firmware. I can login via 192.168.1.1 to the router's home screen (r7000) however every attempt at flashing a different firmware in the gui has failed.
I have tried factory reset in the gui, no go.
The mac address has changed as well to 00:FF:FF:FF:FF:FF. Tried changing it in the gui manually but that doesn't work.
I know nothing about routers, but after reading the forums on here I managed to get the below log file from putty.
I have already invested so much time in attempting to fix this router and would like to but I don't know how and more importantly if it can be salvage.
Any help on this matter would be most appreciated.
Reset
Terminated
: cmd=159: No such device
eth2: cmd=159: No such device
Sending SIGTERM to all processes
Sending Restarting system.
Digital core power voltage set to 1.0V
Decompressing...done
SHMOO VER 1.13
PKID07DC06011801080000000000001A103F01000000
S300001CF
00001380
RDLYW0 00000004
RDENW0 00000033
RDQSW0
0000000000111111111122222222223333333333444444444455555555556666
0123456789012345678901234567890123456789012345678901234567890123
00 -------+++++++++++++++++++++++X++++++++++++++++++++++-----------
01 ---------------+++++++++++++++++++++X+++++++++++++++++++++------
02 ---------+++++++++++++++++++++++X+++++++++++++++++++++++--------
03 --------+++++++++++++++++++++++X++++++++++++++++++++++----------
04 ------++++++++++++++++++++++X+++++++++++++++++++++--------------
05 ---------+++++++++++++++++++++++X+++++++++++++++++++++++--------
06 -------++++++++++++++++++++++X++++++++++++++++++++++------------
07 -----------+++++++++++++++++++++++X+++++++++++++++++++++++------
08 --------++++++++++++++++++++++X+++++++++++++++++++++------------
09 ------------+++++++++++++++++++++++X++++++++++++++++++++++------
10 --------+++++++++++++++++++++++X+++++++++++++++++++++++---------
11 ------------+++++++++++++++++++++++X+++++++++++++++++++++++-----
12 -------+++++++++++++++++++++++X+++++++++++++++++++++++----------
13 -------------++++++++++++++++++++++X++++++++++++++++++++++------
14 ----------+++++++++++++++++++++++X++++++++++++++++++++++--------
15 --------------++++++++++++++++++++++X+++++++++++++++++++++------
PW0
00 ++++++++++++++++++++++++++X++++++++++++++++++++++++++-----------
01 -----++++++++++++++++++++++++++X++++++++++++++++++++++++++------
02 --+++++++++++++++++++++++++++X++++++++++++++++++++++++++--------
03 -++++++++++++++++++++++++++X++++++++++++++++++++++++++----------
04 +++++++++++++++++++++++++X++++++++++++++++++++++++--------------
05 ++++++++++++++++++++++++++++X+++++++++++++++++++++++++++--------
06 ++++++++++++++++++++++++++X+++++++++++++++++++++++++------------
07 ---+++++++++++++++++++++++++++X+++++++++++++++++++++++++++------
08 ++++++++++++++++++++++++++X+++++++++++++++++++++++++------------
09 -----+++++++++++++++++++++++++++X+++++++++++++++++++++++++++----
10 --+++++++++++++++++++++++++++X++++++++++++++++++++++++++--------
11 ------+++++++++++++++++++++++++++++X++++++++++++++++++++++++++--
12 +++++++++++++++++++++++++++X+++++++++++++++++++++++++++---------
13 -------+++++++++++++++++++++++++++X++++++++++++++++++++++++++---
14 --++++++++++++++++++++++++++++X+++++++++++++++++++++++++++------
15 ------+++++++++++++++++++++++++++X++++++++++++++++++++++++++----
NW0
00 ------+++++++++++++++++++++++++X++++++++++++++++++++++++--------
01 ---------------++++++++++++++++++++++++X++++++++++++++++++++++--
02 ----------+++++++++++++++++++++++X+++++++++++++++++++++++-------
03 --------++++++++++++++++++++++++X+++++++++++++++++++++++--------
04 ------+++++++++++++++++++++++X++++++++++++++++++++++------------
05 --------+++++++++++++++++++++++++X++++++++++++++++++++++++------
07 ------------++++++++++++++++++++++++X+++++++++++++++++++++++----
08 --------++++++++++++++++++++++X++++++++++++++++++++++-----------
10 ---------+++++++++++++++++++++++X++++++++++++++++++++++---------
11 -------------+++++++++++++++++++++++X++++++++++++++++++++++-----
13 --------------++++++++++++++++++++++X+++++++++++++++++++++------
14 ---------+++++++++++++++++++++++X+++++++++++++++++++++++--------
15 -------------++++++++++++++++++++++X++++++++++++++++++++++------
WRDQW0
00 +++++++++++++++++++++++X++++++++++++++++++++++-------++++++++++-
01 ++++++++++++++++++++++++X+++++++++++++++++++++++------+++++++++-
02 +++++++++++++++++++++++X++++++++++++++++++++++-------++++++++++-
03 +++++++++++++++++++++++X+++++++++++++++++++++++-------+++++++++-
04 +++++++++++++++++++++X+++++++++++++++++++++----------++++++++++-
05 ++++++++++++++++++++++++X++++++++++++++++++++++++-----+++++++++-
06 +++++++++++++++++++++X+++++++++++++++++++++----------++++++++++-
07 ++++++++++++++++++++++++X++++++++++++++++++++++++-----+++++++++-
08 +++++++++++++++++++++++X++++++++++++++++++++++-------++++++++++-
09 ++++++++++++++++++++++++X+++++++++++++++++++++++---------++++++-
10 +++++++++++++++++++++++X+++++++++++++++++++++++-------+++++++++-
11 ---+++++++++++++++++++++++X++++++++++++++++++++++----------++++-
12 ++++++++++++++++++++++++X+++++++++++++++++++++++-----++++++++++-
13 -++++++++++++++++++++++++X+++++++++++++++++++++++-----------+++-
14 ++++++++++++++++++++++++X+++++++++++++++++++++++-------++++++++-
15 --+++++++++++++++++++++++X+++++++++++++++++++++++----------++++-
WRDMW0 00000022
WRDMW0 00000024
ADDR
00 +++++++++++++++++++S+++++++++++X++++++++++++++++++++++++++++++++
CFE for Foxconn Router R8000 version: v1.0.8
Build Date: Fri May 30 15:03:06 CST 2014
Init Arena
Init Devs.
Boot up from NAND flash...
Bootcode Boot partition size = 524288(0x80000)
DDR Clock: 800 MHz
Info: DDR frequency set from clkfreq=1000,*800*
et2: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 7.14.43.2 (r474543)
CPU type 0x0: 1000MHz
Tot mem: 262144 KBytes
Device eth0: hwaddr 00-FF-FF-FF-FF-FF, ipaddr 192.168.1.1, mask 255.255.255.0
Checking crc...Loader:raw Filesys:raw Dev:nflash0.os File: OptionsSmiley Sadnull)
Loading: ..... 4778464 bytes read
Entry at 0x00008000
Closing network.
Starting program at 0x00008000
console [ttyS0] enabled, bootconsole disabled
brd: module loaded
loop: module loaded
lookup_nflash_rootfs_offset: offset = 0x200000
nflash: squash filesystem with lzma found at block 31
Creating 17 MTD partitions on "nflash":
0x000000200000-0x000002200000 : "linux"
0x0000003e01c4-0x000002200000 : "rootfs"
0x000002200000-0x000002240000 : "board_data"
0x000002240000-0x000002280000 : "POT1"
0x000002280000-0x0000022c0000 : "POT2"
0x0000022c0000-0x000002340000 : "T_Meter1"
0x000002340000-0x0000023c0000 : "T_Meter2"
0x0000023c0000-0x000002400000 : "ML1"
0x000002400000-0x000002440000 : "ML2"
0x000002440000-0x000002480000 : "ML3"
0x000002480000-0x0000024c0000 : "ML4"
0x0000024c0000-0x000002500000 : "ML5"
0x000002500000-0x000002540000 : "ML6"
0x000002540000-0x000002580000 : "ML7"
0x000002580000-0x0000025c0000 : "QoSRule"
PPPoL2TP kernel driver, V0.17
tun: (C) 1999-2004 Max Krasnyansky <[email protected]>
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ehci_hcd 0000:00:0b.1: EHCI Host Controller
ehci_hcd 0000:00:0b.1: new USB bus registered, assigned bus number 1
ehci_hcd 0000:00:0b.1: irq 111, io mem 0x18021000
ehci_hcd 0000:00:0b.1: USB 0.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
ohci_hcd 0000:00:0b.0: OHCI Host Controller
ohci_hcd 0000:00:0b.0: new USB bus registered, assigned bus number 2
ohci_hcd 0000:00:0b.0: irq 111, io mem 0x18022000
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
xhci_hcd 0000:00:0c.0: xHCI Host Controller
xhci_hcd 0000:00:0c.0: new USB bus registered, assigned bus number 3
xhci_hcd 0000:00:0c.0: irq 112, io mem 0x18023000
xhci_hcd 0000:00:0c.0: Failed to enable MSI-X
xhci_hcd 0000:00:0c.0: failed to allocate MSI entry
usb usb3: No SuperSpeed endpoint companion for config 1 interface 0 altsetting 0 ep 129: using minimum values
xHCI xhci_add_endpoint called for root hub
xHCI xhci_check_bandwidth called for root hub
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 1 port detected
Initializing USB Mass Storage driver...
USB Mass Storage support registered.
u32 classifier
Actions configured
TCP cubic registered
NET: Registered protocol family 10
lo: Disabled Privacy Extensions
IPv6 over IPv4 tunneling driver
sit0: Disabled Privacy Extensions
ip6tnl0: Disabled Privacy Extensions
802.1Q VLAN Support v1.8 Ben Greear <[email protected]>
All bugs added by David S. Miller <[email protected]>
Northstar brcmnand NAND Flash Controller driver, Version 0.1 (c) Broadcom Inc. 2 012
NAND device: Manufacturer ID: 0xc2, Chip ID: 0xf1 (Unknown NAND 128MiB 3,3V 8-bi t)
(1,1) (16,2) (32,2) (48,2) (0,0) (0,0) (0,0) (0,0)
Bad eraseblock 251 at 0x000001f60000
Bad eraseblock 322 at 0x000002840000
Bad eraseblock 552 at 0x000004500000
Options: NO_AUTOINCR,NO_READRDY,
Creating 2 MTD partitions on "brcmnand":
0x000002600000-0x000007b00000 : "brcmnand"
0x000007b00000-0x000008000000 : "OpenVPN"
devtmpfs: mounted
Freeing init memory: 216K
tpl
[sighandler]: No more events to be processed, quitting.
[cleanup]: Waiting for children.
[cleanup]: All children terminated.
Reading board data...
PIN number not found!
WSC UUID: 0xd1c9a172b5f7b72f35bb4cf0531b0ec8
NTP synchronized date/time: 00-00-00
MAC address of 1st STA connected: 00-00-00-00-00-00
convert_wlan_params: Unknown WLAN region
invalid RF magic!
No RF parameters! Use default.
### main:1257 Set Normal Power!
Initialise conn table 2048 entries
insmod: proxyarp.ko: no module by that name found
tpl
insmod: usbcore.ko: no module by that name found
insmod: ehci-hcd.ko: no module by that name found
insmod: wl_high.ko: no module by that name found
tpl
tpl
eth1: cmd=14: No such device
wl-1 not up in 3 sec
Hit enter to continue...
BusyBox v1.7.2 (2014-02-12 08:40:26 CST) built-in shell (ash)
# tpl
/bin/sh: tpl: not found
# tpl
# tpl
# tpl
# tpl
# tftpboot
/bin/sh: tftpboot: not found
Utilizing a USB serial, i was able to flash using windows tftp and in CFE with (flash -noheader : flash1.trx) to tomato.
The mac still read 00-FF-FF-FF-FF-FF in tomato.
I tried flashing original r8000 firmware and got the below info. I cannot log into the GUI via192.168.1.1 due to hardware issues i guess.
Any help would be appreciated on what to do next?
I find the majority of info on BOARD ID on the net is no longer available no matter the site, i keep getting Service Unavailable. With that the search results populated are from 2009 -2014 etc on the topic and there's no cache option to view.
pot_magic not match. /dev/mtdblock5
arp_reply_control 3700Trend iqos support.....
rm: cannot remove '/tmp/media/nand/qosd.conf': No such file or directory
rm: cannot remove '/tmp/media/nand/rule.trf': No such file or directory
rm: cannot remove '/tmp/media/nand/TmToNtgr_dev_mapping': No such file or direct ory
rm: cannot remove '/tmp/media/nand/TMDPI/backup/*': No such file or directory
rm: cannot remove '/tmp/media/nand/TMDPI/update/*': No such file or directory
rm: cannot remove '/tmp/media/nand/TMDPI/archive/*': No such file or directory
pot_magic not match. /dev/mtdblock6
POT integrity check failed. ret = -1
Creating device nodes...
Insert IDP engine...
Insert forward module /tmp/trend/bw_forward.ko with param - dev_wan=eth0...
Insert tc module...
Run rule agent to setup signature file /tmp/trend/rule.trf...
init done
...refresh rule db
...refresh rule db
...refresh app db
kaShutDown!
Runnig iqos_cli background mode
ACOSNAT: Set BCMCTF to on
ACOSNAT: Set NAT for LAN domain only to on
ACOSNAT: Set ACOS fpath to on
iqos_cli write to /tmp/iqos_detail
iqos_cli write to /tmp/iqos_top_app
ln: /tmp/etc/crontabs/broker: File exists
ln: /tmp/www/pluging/RemoteShare.htm: File exists
ln: /tmp/www/cgi-bin/RMT_invite.htm: File exists
ln: /tmp/www/cgi-bin/RMT_invite.cgi: File exists
ln: /tmp/www/cgi-bin/func.sh: File exists
sh: can't open /etc/init.d/brokerd.sh
IOCTL_AG_REGION_SET: English
[KC] R8000 IPP v1.2 Start (Apr 28 2015 10:39:05)
Start DHCP client daemon
[Bonjour] Interface: br0 is connected
info, udhcp client (v0.9.8) started
eth0: No such process
[Bonjour] MDNS_CheckName: receive packet timeout
[Bonjour] default device name = R8000
[Bonjour] Answer Name Start (10.0.0.1)
route: ioctl 0x890c failed: No such process
killall: dhcp6c: no process killed
killall: rtsol: no process killed
killall: IPv6-relay: no process killed
killall: pppdv6: no process killed
killall: dhcp6s: no process killed
killall: radvd: no process killed
[KC] R8000 IPP v1.2 Start (Apr 28 2015 10:39:11)
mkdir: cannot create directory '/dev/net': File exists
############ leafp2p_run = 0 username=0
Doing nvram commit by pid 20699 !
killall: xagent: no process killed
Please specify hardware_id (by --hardware_id option) to run xagent.
It should contain only upper latin letters and numbers and have 13 symbols
/opt/xagent/xagent: [-d|--daemon] [-c|--config_file <file name>]
[--disable_console] [--disable_log_file] [--model_id]
[--ca_path <path to CA folder>] [--ca_file <path to cert file>]
[--log_debug|--log_info|--log_warning|--log_error|--log_silent]
[-w|--watchdog] [-v|--version] [--log_file <filename>]
--hardware_id <hardware id>
++++++ run-xagnet.sh ++++++
Tried downloading the R8000-V1.0.0.28_1.0.12_src.tar.zip from here got the following The page you requested does not exist. For your convenience, a search was performed using the query sites default files downloads firmware R8000 R8000 V1 0 0 28 1 0 12 src tar zip.
Thanks, should now be able to get it here.
