Hi
Just wondering if anyone can point me towards an idiot's guide to setting up VLAN tagging on the WAN port of an R9000 running DD-WRT. My ISP (Vodafone NZ) uses IPoE with VLAN Q 10 / P 0.
I've found some threads on setting up VLAN's but none (that work) for just tagging the WAN port. There's also a lot of comments that web gui is unreliable & that it should be done through a terminal session instead but I'm not from a Linux background so am floundering a bit in the dark!
I also found an old thread (2014) where Kong raised a ticket to add this to the web gui (http://svn.dd-wrt.com/ticket/3482) but I don't think it ever happened.
Any help would be appreciated!
Did you find out how to do this with dd-wrt on Netgear R9000?
